New 6.2L logo
If I had the 6.2, I would want it a sleeper. Keeps those ford and dodge guys in awe. ;)
Emblem pros does excellent work. Have had quite a few things made
Z71 emblem
Ryan
Again, leave it a sleeper. I think it is cheesy when car and truck companies advertise what is underneath the good. Cracks me up when I see v6 or v8 badges
With the Borla exhaust my truck would never be mistaken for a sleeper unless it was parked with the engine off... sad but true! Might as well advertise what just ran over that F-150!!!
  • 2 years later...
Where do I order one from? Not sticking that on my fender but I am thinking one will fit nicely on the tailgate....................
Looks great on that factory orange peel paint job! ;-)
I'm all for people doing what makes them happy with their truck. I keep my 6.2 a sleeper. A Ram or F-150 driven by a guy with his buddies inside getting dusted a 4WD Denali is a day his buddies will remind him of for some time. :)
I just had these made at Emblem Pros.......
What does L9H stand for? The 6.2 isn't called a L86 anymore?
L9H is an engine code for the 6.2. There are a few variants. The L9H is the best of them all
Ryan B.
See above
Emblempros.com
Ryan B.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
