My dads 2011 Buick has done this from day 1. He's put 73k miles on it since then. Still squeaks. I hate when I have to drive his car....
There was a TSB for this on the Lambda vehicles (Outlook/Traverse/Acadia/Enclave). It involved changing out the brake booster, master cylinder, and most importantly the brake fluid. I don't have the TSB number but ask the dealer to look up the issue on those vehicles. I had it done to our Enclave a few years ago and the squeak has not been back.
Edited by sk
Thanks. Did some Googling and found it seems to be a common issue. Funny thing is his Enclave is at the dealer right now because its leaking engine coolant from somewhere. His Buick has been by far the shittiest vehicle he's ever had. Problems every 10k miles. First the water pump went out, then the HVAC controller, BOTH heated front seats stopped working, then the ALL of the in-dash air blend actuators stopped working, then his A/C crapped out, now leaking coolant. What a piece of shit. He's waiting for 2015 Sierras/Silverados then I think he is getting rid of that car.
Bad luck lately, literally just had my sisters 2008 Equinox in the shop leaking coolant from a bad head gasket.
Well , well, well. The Damn brake pedal started the squeaking again. Finally got in to the dealer so they could examine. New booster will be installed Friday. WD-40 and other BS is NOT the solution!
What is a booster?
A brake booster makes it easier to push the brake pedal. It is a vacuum assist system. If the car did not have a brake booster, it would be very hard to push the brake pedal and stop the car. The brake booster is located underneath the hood in the engine compartment, behind the brake master cylinder.
Edited by rmackmo
Thanks.
2015 SILVERADO. Squeeke in brake pedal every time it's applied! Had the booster replaced twice and its still squeeke's. This is crazy annoying. Just replaced the booster at jerry seiner in salt lake on 12-23-14. Squeeke is back 12-25-14. MERRY CHRISTMAS.
  • 6 months later...
Bringing this post back. Mine has been squeaking when applying the brakes. Started about 3k ago. At 21k. +/-. I looked at it tonight. the rod that goes from the pedal to the master cylinder is tight and the noise is from the rod going through the boot. I was thinking some grease or lubricate on the rod where it goes through the boot would be the fix. ??? anyone.
Update. Dealer put some silicone looking grease on the push rod at the boot. quiet. Now I know the fix. I didn't want to grease it myself if there was a booster issue, recall etc. Now that the dealer looked at it just greased it, I can do that every few months. Easy enough. I'll use my NAPA bearing grease.
  • 7 months later...
Update again. Whatever the dealer did a few months back in July is over with. My truck has been consistently squeaking on the brake pedal. I cannot get it to stop..
My '16 HD has been doing this off and on since I got it a few weeks ago. The HD trucks have a recall and I wonder if they are related at all. I'll find out when I take it in for the recall in the next few weeks.
^Please update. My truck pedal makes noise 100% of the time time Unreal. I wish I took it in before the 36k warranty ran up. I was so busy and confident it was a bit of grease on the brake pedal rode by the foot well area..... NOT.
  • 7 months later...
2015 Sierra DenAli 28000 miles. Brake pedal squeaks like stepping on an old wood floor. It hsppens both when pressure is applied and released. Sadly this truck has been problems from day 1, literally... Dealership says it's "normal". Any thoughts??
Hello jerrdan2000,
It is important to us that our customers have a positive experience with both our products and dealerships. We regret to hear that you are experiencing these concerns, and would be more than happy to offer our assistance if you choose to continue working with a dealership. Feel free to send us a private message if would like our support.
Take care,
Julianne M.
GM Customer Care
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
