Long time member.....new truck
I couldn't resist the new 2014 trucks any longer so last Saturday I became a 2014 Silverado owner. My kids always name my trucks (usually cartoon characters) and with the deep ruby red metallic color they went for Foghorn Leghorn. Thus my username has changed from Sylvester13 to Foghorn14.
Anyway, they say it doesn't count unless there's pictures, so here pix of the new truck.
366CD342-BA8B-4067-B0C9-E731DC432BFE_zps
6DEFE17E-D57D-4FAA-99EB-19E4D3BBF982_zps
3189681E-44EF-476D-BBFB-D9C75BB0EAFD_zps
21327BAA-D65A-4500-8815-7B6FBE7F30FB_zps
DE2556BA-E0DC-4A45-BAFC-A624EC9F22B7_zps
Sharp truck you got. If i wasn't so attached to black cars, I would have a red one.
Very nice... I am a Sierra fan, but if I were to buy a Silverado that would be the exact model I would buy. I think those are the best looking wheels the Silverado has to offer!!!
Nice truck! Ruby Red is a very good pick.
In my best Foghorn voice.......I say, Now pay attention to me boy, that is a fine looking truck! But I don't see any Chicken Hawks! You better not be haulin any Chicken Hawks in that truck!
Thanks everybody. Last truck was silver and I know I'm going to miss how silver didn't show dirt so badly. I am still in shock of how quiet the K2 trucks are. I know there's lots of posts about folks that have had issues with the new body style; I just hope I can avoid them.
Great looking truck! I love the chrome grill. I bought mine exactly one month ago.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
