I've been holding out on buying this truck for months now waiting for a fix.
I know your hopes are there will be a fix and it may be in 5 or so years when GM rolls out a new generation. But with this generation, a dealer is not going to be able to do anything with body, tranny, and engine mounts. Or length, cabin volume, and metal density. Until that time, the answer will be for dealers to make an extremely annoying level of issues to a less annoying level. A dealer may play with dynamat, tires, wheels, drivetrain, and maybe different suspension items to achieve a less annoying level, but you're going to be holding out for a long time waiting on a fix. A fix is way too costly, complicated, and restrictive for an independent dealer.
Edited by The Zip
CI Houn – My comment seem hopeless, but I say all this because I have read every page and posted on the thread beginning at page one, so I am basing my comments on customer data. I had my Tahoe LT for about 19 months with no dealership downtime and it has always been and continue to drive like butter, so there “is” some hope.
Zip does yours have the issue also?
My truck really is like butter. Having my truck for 21 months (not 19 as stated above), I have never had any shaking, buffeting, vibration, or pressure. Now I did start another thread on pressure, but I think my issue was associated with my particular setup and the XM signal. My fix was as simple as not using those XM channels.
Now there are standard size trucks having issues, but my truck is standard size, Chevy 2013 build cause it was on the road to the dealer in Jan 2014, 20 inch aluminum wheels, no roof rails, no sunroof, no under carriage engine debris protection (similar to a skid plate). I have all options of the LTZ except I have fixed side steps, no Magnetic Ride suspension, no rear entertainment, and no second row captains. Can these issues happen with my truck, yes, because Chevy/GMC/Cadillac all use the same GM platform.
Now reverse what I said for "maximum" issues; XL size, non Chevy 2014 or later build, larger than 20 inch wheels may not be aluminum, roof rails, sunroof, undercarriage protection, moveable side steps, Magnetic Ride suspension, rear entertainment, second row captains. Not scientific but I'm not a GM engineer, the data on this thread (give or take a couple of items) leads to the GMC XL version to include Denali with Magnetic Ride suspension and 22 inch wheels as the truck with the most customer complaints associated with this thread.
I will say though I have not heard “any” complaints from owners of the least expensive of the GM fullsize SUVs, the Tahoe LS. Go figure…
I will say though I have not heard any complaints from owners of the least expensive of the GM fullsize SUVs, the Tahoe LS. Go figure
I had an loaner the first time my truck was in the shop (SLE about as base as you could get) and the buffeting issues were worse in that than they are in my '16 XL Denali w/22" wheels.
First time poster here. I have 850 miles on my 2015i Yukon XL SLT and first noticed the pressure / booming at about 200 miles. Mine only seems to have it from 40-45 MPH, though it does have an annoying highway vibration as well. Fortunately no pressure at those speeds. Taking it into my dealer this coming week and have already forwarded them this thread. The service manager said this is the first one they've had in for the issue, but said he is willing to try anything to make it right.
Frank, can you PM me or post the info for your dealer that was able to fix your vehicle? I would like to get them talking if possible.
What a PIA for a brand new $70k vehicle.
My dealer is Quality Chevrolet in Escondido CA.
As others have mentioned, it is imperative all bows are attached to the roof. Crossbars / surf racks are not a bad idea to disrupt air flow but the roof can react to bumps and wavy pavement.
Frank
Don’t remember if any “owners” spoke about the GMC, but...
I am going full aftermarket (smaller) wheels and (bigger) tires plus more sturdy front/rear sway bars
Rethinking the sway, wouldn't a stiffer suspension make the buffeting worse? My initial thought was it would tighten it up so (hopefully) minimizing what's transmitted to the body
Thoughts?
My Yukon Denali [it buffets and booms] is somewhere in the middle.
  • short wheel base
  • no sunroof
  • standard 20" wheels
  • 2nd row bench
  • no dvd
  • has magnetic suspension
  • 6.2L/8A/3.23's
It's worth noting that people should open a ticket with their dealerships. If this problem is as widespread as it is, this is the best hope of a timely resolution!
The Zip I believe your intentions are well placed BUT, you have made 165 plus posts.
Some good most are discussing the same post over and over or your opinion.
You don’t own one of the vehicles affected and are interpreting, clarifying the posts and expressing your opinion to a point that it might be better to allow the owners to process the information and resolve this problem
The people involved are well educated and doing a great job and are able to understand the post without your re explanations or suggestions.
Your Post 1063 My truck doesn't experience anything associated with this thread.
This forum doesn’t need a self appointed moderator.
Your post 701 Let’s get the thread back on point. I agreed my posts can be shorter, so if I can help (even if it’s just one person) and I need to say it in longer than 4 lines or so, I’ll send you a private message. At the end of the day, everyone will ultimately do what's in their best interest, regardless of what's posted.
If you make a brief comment based on fact not your opinion, and follow your own advice above it would be appreciated.
I have also followed this thread and read all of the posts. This is my first post as I am on the sidelines and appreciate the information provided by the Owners affected with the issues and feel for the pain they are going through. I would like to purchase a Yukon but not till these issues are resolved.
Thank you to all involved.
Lockwasher
Thoughts?
It is very hard to predict these results. It could very well help on one stretch of road only to hurt on another.
If you have the booming, the Dynamat will help with that higher frequency noise. I don't think the Dynamat can help with the buffeting because that frequency is way too low.
I would say check to see if your roof is fastened to the bows and if not get that fixed first.
Frank
Lockwasher - You are on the sidelines and appreciate the information provided by the owners affected with the issues and feel for the pain they are going through. I am an owner not on the sidelines and my posting won’t be defined whether or not my truck is broken. I too feel the pain, you had to have seen that in one of those 165 plus posts. But, shouldn’t it be encouraging to an owner and prospective owner like yourself that I have the same truck in theory and it does not experience the issues associated with this thread?
Hey, point taken!
I had my Yukon XL SLT at the dealer on Friday and the engineer didn't even bother driving it as he was fully aware of the issue. He told my dealer to schedule the service to be done at their body shop and to do the roof bow TSB. He agreed that many times fixing just one bow will not fix it and he claimed that they have had luck getting rid of the buffeting in many cases.
My dealer is fully aware to reattach all bows at a minimum and if possible add additional support to all of them even if they are all attached. Additionally, it sounds as if GM will give approval to add sound dampener as well. I didn't purchase the vehicle from this dealer and I must say they are almost as interested in getting this fixed as I am which is promising.
The dealer wants to reach out to Frank's dealer in Cali and get a detailed list of what they did as t hey too only want to pull the headliner one time.
I am also going to swap out the 22 with 20" wheels.
I will update once the work is completed.
I agree with zip, It's good to hear from people who don't have this issue also to compare why some have it and some don't, what's the difference, if it happened on letter production maybe they used cheaper sheet metal or cut done cornered somewhere or different manufacturer parts. If problem exist within same production dates maybe Rome just got lucky with better assembly. But hearing from owners that doesn't have the issue makes me ask how can it be overall design
Edited by Cl Houn
    LonghornMM
    LonghornMM
  • Who's Online   5 Members, 0 Anonymous, 543 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
