Has anybody tried disconnecting the Active Noise Cancellation fuse to see if that helps with the buffeting feeling yet? My Bose noise cancellation headphones give an intolerable buffeting sensation on my eardrums during takeoff in a plane. I haven't been able to read thru the whole thread, so sorry if I missed this, but I'm considering one of these trucks. The ANC in particular concerns me. Some people can't tolerate the pressure sensation in the ears caused by ANC even when it's working right... My girlfriend being one of them.
Yeah, unfortunately it didn't seem to fix the issue. I think it was back around page 50-60. Cotton balls and tape over the mics helped at least one person to some extent, but the results weren't consistent. When the fuse was pulled it had no effect on the pressure sensation, if I recall.
I pulled the fuse the ANC system on mine and it made no improvement at all.
Which fuse is the Anc? I may try to pull mine just to see. Im desperate to try anything.
IIRC, #48. It's the "amp" fuse on the passenger side.
It had zero influence on the buffeting.
I've had my Yukon back from dealership visit #3 and am pleased to report that I now enjoy driving my Yukon at all speeds!
To recap, I had booming, buffeting and vibrations. Work done on visits #1 and #2 included:
  • road force balancing sessions
  • 3 tires were replaced; 20" Continental; more road force balancing
  • rear axle replacement; rotor to rotor <-- this eliminated all vibration IMHO
  • headliner removal & inspection <-- bows were intact
Last week's visit included:
  • hatch inspection/alignment; it now closes with a solid thud; seals were not replaced
  • 3 tires were replaced with 'certified' 20" Continentals; more road force balancing
  • replacing or installing 6 vibration dampers on the exhaust system; I have no specifics; 3rd hand information
I've driven nearly 400 miles since I picked it up - the buffeting is pretty much gone. I have to actively listen for any buffeting and if I do hear anything, it's barely perceptible. It might even be in my head - more time behind the wheel will ultimately tell. I can't comment on the booming as I haven't driven on snow covered or gravel roads. I will say that it hasn't bothered me in the last week with mixed rural and city driving.
In addition to all the parts & labour listed above, I was able to have GM Canada add additional warranty to my Yukon and my dealership will cover the cost of road force balancing my K02 "snow shoes" which I'm going to keep. Those should be installed in the next week or so, just in time for my 1500 mile drive down to sunny and warm Florida.
As ChrisM. above pointed out, the key is to have a dealership that is ready and willing to support complicated and someone subjective issues that this thread covers. The service manager at my dealership was receptive and great to deal with - I got lucky. The other key was to get GM Canada's "Executive Review Team" involved who ultimately dispatched a knowledgeable field engineer that methodically chipped away at it. I do believe that GM engineers from Michigan got involved at some point too.
All in all, not the ideal car buying experience, but this comes with the territory with buying the first year of a new model.
GM made things right in my books. Fingers crossed that time does not change that.
I wish you could get the part numbers for the vibration dampers. My service said if I could get the part #s they would try in on my Tahoe.
Edited by Ozzii
The invoice did not include part numbers for the dampers - it was simply mentioned in the comments. I'll see if I can dig up any details.
Quick update: I'm still buffet free. The truck is perfectly smooth to 160km/h. With some recent snow, there is a slight booming sound when driving over packs of snow which I'll likely hear on gravel roads too. I can live with that. The low speed boom over expansion joints and concrete transitions is gone.
I really appreciate that ;) If I could get the low speed booming between 1 and 30mph when hitting expansion joints and concrete transitions to go away I would be a happy camper.
Agreed. The low speed booming is annoying. My 2016 Yukon Denali 2wd 20" has also developed a vibration at highway speeds. Just don't have time to take to dealer yet but will soon. Hopefully they play ball.
What kind of tires do you have? Continentals? Does it peak at 70mph?
I've asked my Service Manager to ask the field engineer who installed the dampers for more details. I've also asked GM Canada's review board liaison (who I escalated my case with) to provide more details. I'll share any feedback.
Yes, Continental ContactPlus LX20 if my 2 minute short term memory is correct. It vibrates from 55mph at least through 70 but haven't analyzed a peak. It has just started with ~1600 miles on the odometer. Low speed booming has been present from day 1 but was deemed acceptable compared to the buffeting and vibrations felt on others we test drove.
I would love to hear more about the exhaust dampers. It sounds like the dampers absorb or dissipate the boom and thus, the factory dampers are too stiff? I wonder if others have had success eliminating the boom with new dampers.
Yep, same tires as me. It took 6 replacements to eliminate the buffeting. Check out post #1976 for feedback about the LX20s from other drivers.
The buffeting returned slightly when I put my AT tires on with the worst at 18lbs. Had them corrected to 12lbs or less and it disappeared again.
15lbs or less on a Hunter RF balancer is the key!
In regards to the dampers, I'm unsure if they even came from the factory - these could be net new parts. The only chance I've had to inspect the underside was when I was having my AT tires RF balanced - after the 6 were installed.
Update....
Well, a few weeks ago I reported that with the new 20" winter wheels and tires in, the vehicle was very good. Buffeting and boom all but gone. Well, that changed! We went on vacation and the vehicle sat for 9 days straight. And now, it's back to the way it was with the original tires. It it real bad the first 10 or 20 km, and then quite a bit better. But still not as good as it was before we went away.
Weird? I guess the whole flat-spotting of the tires is a big deal with these vehicles. Of course, it just proves what we've been saying - that these vehicle are overly sensitive to any and all vibration disturbances, and tire are a big one. But of course trying to keep perfect tires on the vehicle is next to impossible. In my case, I was pretty happy wi this new winters, but let it sit around too long and all hell breaks loose again. Now, those tires a "defective" by GM standards, but let's face it... Not being able to let your vehicle sit idle for too long it not practical. And, my F-350 sits for weeks at a time and runs smooth as new when I drive away. Although, I did notice my Explorer had a pretty solid tire vibration for the first trip after we got back from our trip, but it's all smoothed out again. So, flatspotting it definitely a factor, but the GMs are just too damn sensitive!
I'm hoping it's a rear end thing and not tires. I'm sure later down the line if you get after market tires on your own tgey ain't gonna be watching them for you
    • Yes they are a good addition to make the truck more visible.   I have the OE ones in the lower front corners. I added some amber fogs to the bumper from Diode Dynamics SS6 model and wired them to my upfitter switches.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
