2014 Gmc Sierra 1500 1st service
Tattooo
My first 90 day service is a few weeks away & my dealer said they are not changing the break in oil until the scheduled 7500 miles its just an inspection .... 2 year maintenance is included & I always thought it was necessary to get the break in out out ??
My dealer said the same thing when I asked them to do mine @ 3000 miles. They did it anyway and said the service plan is 4 services and I could use them whenever I wanted to until they are all used.
My dealer stated the same as above. I have 4 oil changes in 2 years and I could use them when I needed. Heck I just turned 5800 miles in 9 and 1/2 months. My oil life monitor was at 45% when it was changed about 2 months ago. The original policy by GM was it had to be 20% or less before they paid for an oil change. However that has been changed IIRC.
the metal used on modern motors is so perfect and strong that it does not wear any manufacturing imperfections nor have any shavings of any kind ?Ialways rak 5k on my lexus & old sierra synthetic not 3k & know Its not the 50s but the motors are built by GM not Nasa....Some say that about modern firearms but I still clean & break mine in until I see proof otherwise
No need to change the oil unless you been in extreme conditions or the oil life monitor is below 30%.
There is no "break-in oil"
It's just good common sense to extract the original oil used for the first couple hours of engine use imo. If these engines had no need then there would be no need to place a magnet on the end of the drain plug. For 50 bucks it good cheap insurance on an engine that would cost around 5 grand or more to replace!
I change mine every 5000km (3000miles) regardless of what GM says. I am also a GM tech. I do not believe in this oil monitor system at all.
It's not the metal that is the issue, although clearances and tolerances have much improved over the last 50 years. It's that the oil is better, especially synthetics. It doesn't break down as easily as it used to and it wears longer. It's not a matter of trusting the oil monitor system, it's trusting every new car manufacturing engineers that are now saying that 7,500 mile oil changes are perfectly acceptable. But hey, keep changing it every 3,000 miles if you want for your "piece of mind" because oil (even synthetic) is an infinite resource. Right? Right?
That's just part of it the engines are more efficient, fuel injection, quick warm ups hotter running temps, hotter spark. I got 6,000 miles on my truck cant hardly see the oil on the stick yet. I got one for you, Ive seen studies stating if you change oil too often its worse because of the detergents in the oil. My trail blazer had mobil one the light came on at around 15K, I beat the sh^t out of it, at 130K I sold it still running good using no oil.
I will push the dealer to change the oil ....if not im sure It will be just fine
The dealer is just giving you lip service, find another one.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
