Where are you putting your accessory switches?
I have a 2014 GMC Sierra SLT 1500 with the buckets and console option.
As I look at my dash I don't see a whole lot of choices for installation of accessory switches.
I figure I need about four switches (under bumper backup lights, additional front lighting, possible sprintbooster, and one more for later)
The under bumper backup lights (rigid) are a round 3-way switch (on all the time/off/on when in reverse)
I expect additional rigid lights would use a similar style and size switch.
The sprintbooster switch I might have to use what it comes with. The pics show a hardwired almost remote looking switch. It should have 3 settings (stock/medium/high). I don't know if it can be replaced with a 3-way switch like the rigid backup lights use.
Can you share pics of your switch locations and installations?
Thanks much.
R
  • 3 weeks later...
Been thinking about the same thing.
My thought is maybe fabbing something up where the factory trailer brake should go. I kinda wish they did a flat spot there instead of that useless pocket for those of us who didn't get that.
Other option, if you have the full console, maybe take out one of the cig lighters or the usb connectors in your console and put them in that area?
My third option (and I really dont think I wanna do this) is to put them beside the radio in the black part of the bezel, OR down where the heated seat buttons go (if you don't have heated seats like I do)
Final location for me would be bottom of the dash around where your left knee rests. May wind up bumping them on bumpy roads though.
Right now I'm looking at a couple of blank spots in the roof console. I need to figure out how to take it off to see if there's room back there.
Good idea. Hadn't considered the roof console. I don't have homelink or moonroof, so there should be PLENTY of room.
Used to be to remove em you had to slide it toward the windshield and pull down. Don't quote me on that, but I know on older ones you removed a screw from the front center and then the entire unit slid forward to disengage from the bracket in the ceiling.
Routing may be a bit of a pain if you have a bunch of switches to run though.
The top lip of the knee panel by the steering wheel looks good. It was done on a build but I can't find the photos.
Sent from the future via a wifi time portal.
That's the spot, or use the sunglasses holder (modified of course)
Personally I'm thinking the face of the flip down storage tray right below the T/C and bed light switches in the center console. For me it's pretty useless for anything else as it's still about the size of an astray. Access for running wires and fitting the switches is a breeze, the location is easily accessible and if I screw it up or decide to go back to stock later it's a comparatively cheap piece to replace.
*Comparative being the operative word here. When I called the dealer I was quoted 70.00 for a replacement tray. I called because I was originally going to try and hide my brake controller inside of the tray, but it's not deep enough by a hair.
  • 8 months later...
Finally mounted my switches and it's pretty sweet!
3 On|Off
1 On|Off|On
maybe on or in that pop out drawer, coin holder, thing under neath the radio below the cig lighter.
Could you expand on this? Maybe a pic of it open? Thx.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
