Driveless Cadillac by 2017
kt88
That is my problem, everything is connected now. Would it really be that hard for someone to hack into a car? Hack it, fire it up, and let it take itself right to the chop shop. No thanks.
Well, from everything I have read regarding where they are heading with autonomous commercial trucks, I see some serious bottle necks occurring. These things will be operating in the 55 mph range, and they will have all the safe vehicle space stuff programmed in. Every time a 4-wheeler cuts in too close in front of one of these autonomous trucks, it is going to slow or brake to keep safe following distance. Then another 4-wheeler cuts in and the cycle continues. It is not unreasonable to see these things going 45 mph in 65-70 mph heavy traffic. Really find if hard to believe that things will then be safer. Speed does not kill, else everyone at Daytona would be dead. It is differential speed that kills. Autos with this stuff can be one thing, commercial trucks are quite another. There are just too many variables that folks who live in cubicles have no concept of. After over 3 decades in commercial trucking, i have no worries that my business is quite secure to long after I am retired before this stuff even becomes much of a reality in the real world. It would be lot of fun watching the fiasco of an autonomous truck running down, say, I-35 between Dallas and Austin, or the tri-state around Chicago.
Makes one wonder how some idiot with road rage is going to take it out on a computer driven vehicle!
You a trucker too?
I was born to a trucker and raised by a trucker, taught the right way!
Yeah, grew up around trucking on the farm in the 60's, but really didn't start at it till '82 while living in Alaska.
Cowpie those backups ready happen in Michigan. :lol:
There is tons of truck traffic and most seem limited to 60-65. Limit here is 70 but realistically folks do 80 or so. Get one truck trying to pass another on what passes for a grade around here and you'll get traffic backed up for miles doing 40.
Yeah, I frequent MI a lot. Speed limit for autos/pickups is 70, but speed limit for commercial heavy trucks is 60 mph, state wide. Whenever you have trucks hitting hard pulls, already slower than the regular flow of traffic, and they bog down on the pull, it really messes things up.
This is why I'm interested in seeing how they develop the "super cruise." I feel like its going to work similar to these trucks so if you get cut off its going to slow you down to gain back the safe travel distance then speed back up.
I really don't think you will see "driverless" vehicles outside of cities for a long time, and when I say cities, I mean downtown cities with no highways involved. A true driverless vehicle won't have any way of actually controlling the vehicle, you would be introducing a human element into a system that HAS to be completely autonomous, which is why i say you won't see anything outside of cities. Computers are just as good as we are at figuring out if some moron is about to cut us off.
or as they say, its not the fall that kills you, its the Sudden Stop when you hit the ground!
  • 1 month later...
Maybe (driverless) I could own a vehicle for when I am a 100 years plus. I might not know (at that age) where I will be going but I will get there safe and sound.
It's already here just get out of your car when it's moving
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
