LED light mounting
rododenbach
Does anyone know if the home link will work for two light bars? Like if I buy two remote harnesses, can I program each to a different home link button?
  • Replies 185
What brand? Got a link where you got it?
It's made by OZ-USA. Here's the link.
https://www.amazon.com/dp/B00V9QJTCY/ref=cm_sw_r_cp_awd_fpDFwb42CVZ5Q
I know it works with a single wireless harness. I couldn't imagine it wouldn't work with two of them. Only negative thing I've heard is there is a slight delay when using home link buttons.
Ok. I'm ok with a slight delay. I can't picture myself ever needing to flip them on quickly anyways. I'm going to go ahead and pick up the two harnesses and fingers crossed they work lol
Has anyone used a light bar cradle? Anyone seen a write up of some one who has? Without trimming anything it looks like the largest you could do using a cradle is 30" but I would consider it if I knew for sure it would work. I am thinking of using a home link for my switch or put my switch like Kerrslight did his. I just think that was genius. I had been racking my brain on where to hide a switch and can't believe I didn't think if that. Thank buddy. Great idea
Glad you like it brother. I got the idea from someone else on here and thought the same thing.
Thats it? Is this yours? What light bar, swithches and mounts did you use?
Hey man I am install the light bar now and placing my switch in the 12v aux power like you did. How did you get the aux power outlet out to be able to put the led light bar switch in? I am auctually doing this right now and had to stop to message you. If you see this please answer ASAP.
Hey, sorry for the delay. To remove the six power outlet, there are two plastic taps holding it in place. If you have a trim pick, you can reach inside the aux port and press them out, then slowly press the aux port out.
The manufacturer is me and the type is cool - I literally made them. I guess I should have these for sale haha:
Do you have a pair for sale? Please Pm. Thanks
I did the 32" lightbar install on my 15 all terrain , thanks to everyone for posting all the pics they saved me hours of work. Also used the wireless remote with my home link buttons works perfect .
It's shutting off the lights quickly that is needed.
I have no delay turning my light on or off using the home link buttons
Are you talking about using your garage door opening switches to turn your light bar on and off?
If so that is genius. How did you get the switch to learn?
Yes I got the idea from someone on this board. FYI you will need to use a 2 spots one for on and one for off.
Just hold the button on the home link you want to use, when it starts flashing fast hold down the lightbar remote button. When the light goes solid you are All set .
    Camyon
    Camyon
  • Who's Online   5 Members, 1 Anonymous, 976 Guests (See full list)
