Tailgate misaligned?
darkfox1
Hey yall,
So first off I'm pretty sure this isn't a warranty issue or anything but, I would still like some help here, cos I don't know what to do.
When I bought my truck the tailgate was squeaking. The salesman looked and concluded that it was just a hinge that needed some grease. the other day when I was closing my tailgate I noticed though that this is not the case. The tailgate is squealing because its GRINDING ON MY TRUCK BED!
See the pics. I could try to take it off and align it, but it's so close on the other side..
Is my truck out of spec or something??
The other side doesn't have a lot of room either.
  • Replies 33
I'd take it back and make the dealership make it right. Your salesman shouldn't be making any determination of "what's wrong", that's the service dept's job. Your bed and/or tailgate need to be adjusted as that is most certainly not a very good alignment of parts.
Ya it's not the salesman's job to say what is or isn't wrong since his/her only job is to sell a vehicle. Take it to the service department and let them check it out. If possible ask for a GM certified tech instead of a normal tech.
Well the truck was used. It's still under full factory warranty. They shoulda fixed this when it was traded in before the thing went to market in the first place.
you probably notice that black clip thing on the right is broken too. Someone took this tailgate off for some reason and didn't put it back on right, is my best guess.
It's a hassle to take to the dealers out here, LONG lines in the mornings, it has to be an all day thing with these folks. That's why I hesitate, but if it's not something I can just fix in my garage here.. that's what i'll have to do I reckon.
The black plastic piece looks like just a end cap sleeve and can probably just slide off once you take that end of the tailgate out. Taking the tailgate off isn't hard. You just undo the cables and you see how that piece on the right isn't a circle, but has 2 straight ends. Just lift the tailgate up just enough so those straight piece line up with the slot bolted onto the bed side. The other end just slides off. Takes all of 5 seconds, but in your case you just need to left the passenger side out of the slot.
As for the alignment, does the tailgate slide to the driver side any or is there 0 movement side to side?
I've tried to wiggle it side to side, it won't move at all. It opens and closes smoothly and the gentle fall or whatever they call it seems to be working, just makes a god awful sound. Especially when you close it.
I also worry about the long term effects it has, a good place to have rust in 20 years...
Can someone show me what this is SUPPOSED to look like on the passenger side? clearance, and the hinge joint?
Here's my driver side hinge.
I see why. The part of the hinge that's bolted to the bed must be too far in, like the bent angle is too far out. The reason it won't move is because the outside half the of the tailgate hits both hinges like it's supposed to. The passenger side looks to have adjustment room, but the driver side doesn't. Or is that just the angle because mine doesn't hit the hinge. I would take a pic but I have a black truck so it's harder to see, it's also raining hard enough not to worry with it lol.
Hey darkfox1,
Sorry about the squealing noise you're experiencing with the tailgate on your Silverado. I understand you're hesitate to go to the dealer regarding this concern and may attempt to resolve this yourself. Although I'm unable to provide technical advice as it's not my expertise, I'm happy to contact your dealership if you change your mind and look into this further. Just send a private message if I can be of any assistance.
Sincerely,
Eddie A.
GM Customer Care
I think you need a whole new bed. Yours looks like it was welded together to much. Unless the sides are adjustable ...
Check out my gap.
10547832_10152136082911525_4949587842650
Probably wrecked, poorly repaired, attempted to hide it and salesman instructed to convince you there is nothing wrong with it. I'd get it taken care of ASAP, or you may regret it someday when paint starts coming off and rust apperas.
Would a CarFax apply to this type of situation - 'if' the truck was wrecked and the dealer got it back and resold it. Would the state dept of motor vehicle have a 'title' to the previous owner 'if' the truck had been previously sold?
If the truck had actually been wrecked and the dealer said it was not, is there any way to check? Would sure hate to tell the OP he bought a wrecked truck if in fact it was not! That could ruin his day :-)
I would not put anything past a dealer. I bought a new 14 Silverado that Carfax showed as a previously titled truck. A call to GM got me out of it and into another one.
I'm thinking they just assembled the bed wrong it's off its position when they welded it together and now the gate is to tight.
I got a carfax before I made any commitment, no wrecks are shown, accidents, repairs.. nothin.
There's only 2 lines in the carfax that bother me and neither of them involve the bed.
still, SOMETHING had to happen between now and when the truck was built to make this out of alignment like this. SURELY GM wouldn't send a vehicle off the assembly line with this problem.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 417 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
