Rear end springs
Do you want to be level when unloaded and pretty quickly be able to support a load without sagging? Supersprings Part #SSA8 with MKTK and long shackles will give you the best of both worlds imo. It does give you about 1/2 inch at the most relaxed setting but is capable of supporting a lot of weight. The NHT springs don't appear to be any different (I have them) than regular springs. Wouldn't you need custom bags to give you the right load support with that lift?
This is what I would love to do if I had the $$ in my budget.
I ended up ditching the mounting kit and just using the poly pad with short shackles up front and long ones in the rear.
I have BDS rear springs on mine and there are 5 leafs plus over load in it if memory serves. It rides better than stock but I still put self leveling air bags on as I want it completely level when I tow. The springs were 400.
