Media voice command tricks?
Hi Tom Boswell,
Our Infotainment Customer Support Team would be more than happy to assist you with your radio related questions. They can be reached at 855-478-7767, seven days a week, between the hours of 8AM - 10PM EST.
Regards,
Andraya R.
GM Customer Care
I thought I was going to get into fight with my truck today. All I asked the prompt to do was "Call Home". It tried to call every thing but "Home". It was easier just to reach over and push a button. The voice on the truck shure sounds sexy but I think "SHE's" a little deaf. LOL.
All voice command controls are a little fickle. I have had pretty good luck with my making simple calls to contacts on my phone but I have not attempted to use VC's for media. Will try tonight when I leave work but do not have high expectations.
SCOTT19677
Next time push the button, wait for the voice to tell you to say a command, say phone and wait 1 second, then say call home.
Mine worked great when I first bought it back June. Now its horrible, it understands me only about 10% of the time :mad:
Mine works great with my iPhone 6, it sucked with my Galaxy S5, it was great with my iPhone 4S.
Ive had the 12 ford sync and the 14 GM mylink. Both have issues recognizing commands with my deep bass voice.
I can say it helps immensely with both systems if you dont have a southern accent too.
I had to change my MOM contact to MOTHER, and my HOME contact to MY HOUSE because everytime I said CALL MOM, it said CALLING HOME, and vice versa. Had to change another contacts first name from TERI, to TERESA because the mylink would not recognize the name TERI. Another friend is named TERRY (guy) and Ive joked about changing his contact first name to TERESA too because I cannot voice dial him in my truck. Weird, but true.
IME, speaking slowly and enuciating each syllable clearly will help, but it dont ever work 100% for me.
my truck was built in mexico
but I got rosetta stone so we should be able to communicate in 6months to a year :happysad::cheers:
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
