VLED V3 Trition
Mike1220
Hey guys, so tonight I finally received my VLED V3 Triton replacement bulbs for my front turn signals. Officially landing me the ability to say that I have now changed all non-LED lighting from the factory to LED and or HID. All things but my headlights are LED now. But this thread isn't just to express that I am now completely halogen free. It's to post pics of my V3 Triton and anyone else who switches to the triton they can post pics here too for anyone who is considering getting them.
I personally got these because I am getting my turn signals tinted next week when I get halos and FXR projectors installed.
And now the moment we have been waiting for. I introduce the V3 Trition bulb!
Left is stock, right is V3 Trition
833C4CFF-EB8F-4AA7-ABC6-5D3247E313C9_zps
245693C8-95AE-4875-A738-2543AE99C94E_zps
V3 Triton in both turn signals
AA96AD90-40ED-4C3E-A018-ED9C980254DC_zps
Here's how much light they put out comparison pictures!
No lights on except a lamp on the porch and the engine bay lights
AB30DD6C-F662-4851-A990-0F4C61CB9F04_zps
V3's on
37E1D473-BC88-4E4E-B2C9-F38D014303D8_zps
V3's + headlights
921EC794-1CB1-4BD9-9B7A-64079770F9CC_zps
I am picking everything up right now and heading inside soon. I will upload some action videos to YouTube and post links here after I do so.
Hope this helps anyone who is considering getting the V3's!
Boh turn signals with V3 triton
V3 Trition vs Stock halogen.
Wow,they look awesome. A friend of mine with a 2015 HD Sierra did the tail lights with those bulbs and they are bright as hell!! What LED headlight did you use?
Headlights are the only NON-LED. They are DDMtuning.com 55W HID kit. I am changing them out for a TRS 5five kit and a new projector.
These things really are bright! Hell, I was thinking of removing the amber piece and putting a switchback. I'm glad I decided against that! That would've been WAY TOO bright!!
thats funny because thats what i wanna to when i pull my headlights apart..pull the reflectors and get the switchbacks.. they are damm bright though!
  • 5 weeks later...
which bulbs did you use for rear brake and turn? which resisters?
I have full LED replacement housings from Anzo. Well, they are actually from Eagle Eyes, but they are the same thing as what is from Anzo. I have the red lens ones that look just like the factory tail lights.
  • 4 weeks later...
I think I want the switchbacks, so everything is white while running straight . How will I remove the amber from the turn signal lenses?
You have to pull the headlight apart. Either bake the headlight, use a heat gun, or cut the headlight open. From there I have been told that it is pretty self explanatory and very easy to remove the ambers in both the Sierra and Silverado headlights.
  • 1 month later...
Mike, what was the process for installing the V3 tritons for your turn signals - remove the grill, etc? Did you use the 6 ohm resistors from VLEDs with their resistor adapters?
I have the V3 Triton Gen 2.0. They have a built in resistor so all you have to do is put in a 5A fuse to activate the resistor. It's already wires in, just needed to plug the fuse into the holder.
Everything was PNP. Since its a universal bulb, it has a basic plug that comes from the ballast but when you order the V3s, you'll specify what socket you'll need and they will send you a plug that will go to the ballast's plug and make it PNP to your OEM plug.
The Gen 2.5 bulbs that they have now, I cannot imagine would be much different. I think the only difference is the resistor. Not sure if they are built in anymore.
As far as installation goes:
Do you need to remove the grille?
It's not a necessity to do so.
Is it easier if you take off the grille and remove the headlights to gain access to the turn signals?
YES!
Would i recommend you remove the grille and headlights?
I highly highly recommend that you remove the grille and headlights. The V3 is larger than your stock bulb just slightly and the back end that sticks out is far larger. I tried removing and reinstalling my V3s this past weekend without removing the grille and headlights, and I ended up popping the "top" for the tritons that disburse the light. I was able to super glue it back on but after that, I pulled off the grille and headlight and put it back in.
EDIT:
Ps.
I took out the V3 to test fit it in the reverse housing to see if it would fit. It's not a direct swap since the top that disperses the light is too large to fit into the 921 socket. But you can modify the socket by cutting the hole larger to get it to fit.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
    • 60psi front and 80psi rear But I am not running the factory tire brand or size! it's load range F Toyo tires
