Volucris Posted December 12, 2014 Posted December 12, 2014 I was getting my oil changed toady and had them change the power steering fluid as well. Truck has a 100K on it and I thought it was time. They replaced the power steering fluid with ATF. Doing a little reserach here I find that was a poor choice. I'd like to go back andf have them do it over and di it right, but I need more than a website as a good source saying don't use ATF. Any ideas or can anyone point me to a source? What's the difference between ATF and PSF anyway? 2007 Silverado Classic (GMT800)
LeoS41280 Posted December 12, 2014 Posted December 12, 2014 ATF has additives in it to soften seals inside a trans. When it is put in a PS system the additives tend to destroy the hoses.
Volucris Posted December 12, 2014 Author Posted December 12, 2014 OK - But lots of manufacturers says to use ATF for the power steering. I imagine they would have the same problem with their hoses.
kstruckcountry Posted December 12, 2014 Posted December 12, 2014 Different systems. I would flush it and fill it back with PS fluid. Not a hard job.
LeoS41280 Posted December 12, 2014 Posted December 12, 2014 OK - But lots of manufacturers says to use ATF for the power steering. I imagine they would have the same problem with their hoses. ATF is OK to use in a pinch. I'm sure there will be many people tell you here that they have been using ATF in their PS systems for millions of miles without any problem. Do what you want.
Duelin Posted December 12, 2014 Posted December 12, 2014 I wonder why General Motors uses Power Steering Fluid instead of Transmission Fluid. They could save a lot of money by using tranny fluid. They wouldn't even have to stock P/S fluid. HHHhhhhMMMMmmmm I don't know do you?
Volucris Posted December 12, 2014 Author Posted December 12, 2014 "HHHhhhhMMMMmmmm I don't know do you?" Well, obviously I don't or I wouldn't have asked. That's how asking questions works.
DaveH71 Posted December 12, 2014 Posted December 12, 2014 While its not a huge deal that's going to make your truck burst into a ball of flames it would be a good idea to go back and ask them to put the correct fluid in your power steering system. GM recommends power steering fluid, just show them your owners manual where it says GM POWER STEERING FLUID under fluid recommendations
SouthernSilveradoGuy85 Posted December 12, 2014 Posted December 12, 2014 Maybe the reason they put in ATF was because they probably have more of it around than power steering fluid. I never understood the thought behind putting ATF in a power steering system since it's not the same type of system. Take it back and raise hell. Or drain it yourself so you know what's put in it.
Duelin Posted December 13, 2014 Posted December 13, 2014 "HHHhhhhMMMMmmmm I don't know do you?" Well, obviously I don't or I wouldn't have asked. That's how asking questions works. Well I thought that you might step back ask yourself that question. Why Gm would use two different fluid if they could only use one and save a lot of money in the process. Each one is designed to do a specific job. And I guess Gm feels (or should I say knows) that the transmission fluid can't do the job that they want it to do in their power steering systems. Also how much money do you think GM spent engineering and testing these systems? Sometimes they work on these designs for years before they go into production. And leave me add this. If Gm didn't want to save money then their accounting system wouldn't be based on a thousand of a cent. So in closing my logic would be if GM doesn't want to use it then it would be a good idea if I didn't use.
Volucris Posted December 13, 2014 Author Posted December 13, 2014 <i>So in closing my logic would be if GM doesn't want to use it then it would be a good idea if I didn't use.<.i> I don't disagree with anything you said. And I will change it out. That was never in doubt. However, what is the difference between ATF and PSF. Viscosity? Flash point? Additives? Are they incompatible, or can they be mixed? Is it the same as $80 dollar vodka vs $30 vodka, a $50 bottle?
Black02Silverado Posted December 13, 2014 Posted December 13, 2014 There are others on other forums running ATF with no issues. I for one put in what the manufacture recommends. PS fluid is what is called for in your application. That is what needs to be in the system if you ask me. Now GM is moving to dexron VI for PS system in the Acaida. They are having issues with the Acadia systems going bad with bad pumps. So the new fix is to replace the pump and all seals and install fresh dexron VI fluid. That TSB states to make sure the system is flushed of PS fluid and if the new seals are not put in then the ATF will cause leaks. Now this is on the Acadia, how much different it is from the truck line, not sure but like I said, if it calls for PS fluid that is what I would put in. If you want to go with a good synthetic fluid. AMSOIL's power steering fluid is a good choice.
