For some reason, my garage door opener will only work if I'm right up against the door with the truck. In my wife's Buick, which I assume uses the same setup, she can open her door from the street as she's turning into the driveway. I normally back into the garage, but I switched to driving in forward this week to see if it worked any better, to no avail. My driveway is only about 60-70' long, so it's not like it's a country mile.
Every other vehicle I've owned, along with the supplied remotes for the door, will open the door from the street.
Anyone else have this issue?
I'm able to open my garage from the street before I even pull into my driveway. There's definitely something wrong with yours.
Just curious, for those of you who are having distance issues, is your garage at street level or higher?
Mine works from the down the street - previous truck did too.
This issue has been posted before, so you're not the only one. Sorry i don't recall the outcome of the previous post.
Try reteaching it, and/or teaching it on one of the other buttons.
Post your results for others.
Mine needs to be close too. I have heard that you want a brand new battery when you sync the controller to your truck. I know mine was not new back then, but I intend to see if I can re-sync with a brand new battery this weekend. I guess that the newer battery sends a stronger signal, and therefore syncs in a stronger signal to your trucks controller. I'll let you know if it works.
"Hell, I'd piss on a spark plug if I thought it would do any good"!
Same issue on my '14 Sierra. Our Enclave, Jeep and the remotes that came with the opener will get the job done from out in the street (60' Driveway). My new truck only opens the door half of the time and then, the truck has to be just inches from the door (thank goodness for parking assist). I've never had success down the on the street or in the driveway.
I took the truck to the dealer today and was questioned if I properly "trained and learned" the remote to the truck then the truck to the opener. Obviously I did since it works occasionally. One of my "We Owe" items requires a part to be ordered so when that arrives, they're going to check out the transmitter. I'm a little concerned because the service writer didn't seem too optimistic about the fix.
I have to be right next to the garage door also. The remote that came with the door opener works almost a half block away.
This problem in not unique to our trucks. Do a Google search and you will find a ton of hits with different makes and models.
I appears to me that the Homelink transmitters vary considerably in their power output from one unit to the next.
Homelink is useless for customer support. They always seem to say the same thing (Make sure your training remote has a new battery and re-learn).
My garage floor is approximately 42-48" above the grade of the street.
I will try the new battery in the remote. The one in there is not very old, and it worked fine programming the wife's Buick 3 weeks before programming my truck, but it's a cheap fix. I'll also try programming a different button. Won't be able to get to it until next weekend, but I will report the results.
Thanks for these tips.
I put a new battery in the garage remote. Cancelled the previous home link setting, and relearned the the trucks remote. It did increase my range from right in front of the garage door to half way down my driveway. Not great but better. The hand remote will open the garage door from the road at the edge of the yard, which is over 2x the distance.
I may try a new frequency setting code on the opener, if the door isn't moving fast enough. Doubt that it will make a difference, but you never know?
At least I don't have to kiss the garage door with the front bumper now to get it to open.
I put and extension on my garage door opener antenna. Ran a 10 ft piece of wire and spliced it to the antenna wore.
The door opens fine now. The homelink seems fairly directional in the trucks. Had no issues with my Treaverse's I owned before.
Same issue here with my 2014 Sierra and our 2015 Yukon. Thanks to the previous posters for the tips. I'll give em a try.
Our 2014 Tahoe works great from 60 feet away but our 2014 Silverado works if I pull up directly in front of garage door.
Milo's iPhone
this is a common issue and fix for the home links in all gms'
i had this issue in my old car, put a fresh battery in the standard remote and programmed it.
i havent gotten around to programming my truck yet.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
