On 5/6/2018 at 12:03 AM, 2009GMC said:
Have them check torque on all bolts. Sway bar links, the 3 top shock nuts and 2 lower nuts. Upper and lower Ball joints, tie rods.
did you have it aligned? Your toe changed due lift. Only adjustment should have been tie rods.
Something is just barely loose and allowing a slight movement
Just had them check over everything. They drove it and checked it 3 different times and couldn’t find as issue. I watched them tighten everything and double check everything. I guess it was something already wrong before I got the shocks added, so now I have to hope my extended warranty will cover it workout being voided. I was told since I added shocks and struts versus just a spacer kit it wouldn’t void anything. Now I can only hope
If you have a torque wrench I would recommend finding the factory torque specs on her. Most is 36 ft lbs and 90 degrees pass. Most mechanics at shops today are not very good. I would about 10% of mechanics are real intelligent and actually care.
I am sure the answer is in this thread, but its way too long to read every post. I have a 14 AT with an RC 2" level stock shocks. Wanting to replace and it looks like the 5100 is the best way to go (correct me if Im wrong).
If I go with the 5100, do I remove the level and install the 5100s at max height or leave the level and install at stock setting? OR can I leave the level and install at max height to make it effectively a 4" lift?
Well, you could get coil overs that would ride even better, so I guess 5100s could or couldn’t be the best way to go, it’s all relative to whatever you’ve got in mind.
You can do any option you’ve listed of the 3, the best option is relative to what you want to achieve. Looking to stay level and have a smooth ride? are you looking to go 4” up front and leave the back at stock height with the Billy’s? Only the fronts are adjustable, This would achieve the dirty diaper look; but you’d be riding rough and more than likely be replacing/upgrading some other components upfront sooner than later. If you are going to keep them at stock height with your current level, then there would really be no need to purchase the adjustable series.
Thanks. Reading more about it, I’m leaning towards removing the level and going with rancho quicklift.
Guys,
I fortunately got 155k out of my front 2015 Sierra Denali Magneride components. I'm replacing with the Bilstein 5100's. I've ready many posts about installs. However, I can't find a definitive resource regarding what needs to be swapped out of the Denali/Magneride front strut setup to basically make it an SLT or lower trim front strut setup. Do I need just the new non-Denali strut mounts (KYB SM5861), or should I replace more components like the spring, bumper, cup, etc. to pair with the Bilsteins? I have the Xineering magneride delete components to handle the electronic side. I just need to know what components need swapped out to welcome a traditional Bilstein install in place of the Magneride shock.
Thank you.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,993 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
