1 hour ago, newdude said:
Seeing they are two different part #s...do you think they are the same?
Because they are not.  64 is with heated steering wheel, 63 is without heated steering wheel.
Fair enough, the reason I asked is because when you put the 64 number on ebay many 63 come up as if they're interchangeable.
On a side note, looks like the OEM clockspring price doubled...
  • 6 months later...
I managed to score a used wheel for cheap and ordered what everything led me to believe was the correct clock spring for my 2018 3500. However, the clock spring appears to be a 2014-2017, and 2018 have the new style plug.
My truck already has the plug under the dash that would mate with the one pictured below. Clocks springs for 2018-2019 are hard to find, and $150.
Does anyone have a part number for a pigtail with this plug? I'd much rather cut the old one off and crimp on a new one than spend another $150 and have to tear everything back apart.
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
