My Wheel Project
Spurshot
I've been taking guff about my 'old man' wheels from my neighbor ever since I got my truck in the spring. The thing is; he's right. I am an old man. Him too. smiley_quickdraw.gif
So, I have been looking for wheels for about 6 months now. I found some here and there that I liked ok. But nothing stood out to me except these.
I didn't like the black ones nor the metallic gray ones. I wanted chrome.
So, I've been busy. I bought the wheels a week ago, fit checked them on the front and drove them to the plater. The wheels got stripped and polished, then copper plated, polished some more, then nickel strike and chrome plated (triple chromed)
I have some work to do yet. The faux beadlock bolts need to go back in. I'm still on the fence on the colored beadlock ring. Maybe. But I really like these.
  • Replies 62
I'm not exactly a big fan of beadlocks unless they're real which I think it's only a couple real beadlocks that are DOT approved (could be wrong, just last I read). I think your truck would look better with black rims since it's a white truck, but I like full chrome also.
SSG,
I appreciate your comments. I'm just not a black wheel fan at all. There are no beadlock wheels legal to use on the highway, unless they are like the Ford Raptor wheels are DOT approved where the real beadlock ring is not installed and the tire is run inside the bead of the wheel. Just my put, but about all of the truck wheels that have some bead detail, in some way are a play on the real beadlocks.
I stand corrected. The Hutchinson internal beadlock wheels are DOT approved.
SSG,
I appreciate your comments. I'm just not a black wheel fan at all. There are no beadlock wheels legal to use on the highway, unless they are like the Ford Raptor wheels where the real beadlock ring is not installed and the tire is run inside the bead of the wheel.
They're out there but they use a different system I believe than the regular off-road beadlock. Hutchinson and BAD Wheels Inc have DOT approved beadlocks and that's just from the 1st page from a quick google search.
I stand corrected. Still, I don't need a beadlock.
I wouldn't either, only if I had something that wasn't even legal to be on the street. I think those rims look good as is without the fake beadlock rings.
Kind of a backhanded compliment, but a compliment. :D I'll live thru the fake beadlock. They kinda grew on me. But this black wheel craze...I don't get it. From 20 yards they could be steel wheels and nobody would know. Black wheels just disappear. When the black wheel fad is over, the wheel companies will celebrate. They're competing with a spray can of bbq paint right now.
I don't follow fads unless I actually like it. I just think black rims look best on black or white trucks. Any other color it doesn't matter. That's no different than the color match phase which you've done and you've done it because you like the look, not because it's a fade. When I was younger I was in my chrome phase and wanted everything chrome. Now some chrome looks good and is tasteful, but I don't like much anymore.
White with black looks sharp on some cars, my truck is white and I really like how the AT 20" wheel looks on it since it is gun metal in color. The Vette we are thinking of building will be white with the forged black wheels, it really looks stunning on the new Vette.
I live in southern California. It is the birthplace of most vehicle fads. Aftermarket accessorized vehicles are as common as toenail fungus. We all follow fads. Some more than others. It's all personal taste evolved thru emersion in the fads, in the end, especially with something as ubiquitous as a car/truck wheel. Most things related to styles that are retailed are all about fads. Wheels very much included. I've seen wheel fads come and go over the last 4-5 decades and have my personal taste pretty well established. I just can't get into black. It just looks ... blaaah-k to me.
not a fan of fake bead lock wheels. I would keep what you have or get some OEM 20s over the ones you posted above.
Got it. But, I don't like the ghetto look of 20's on a 4x4. These are my choice for my ride.
I have never had anything but black wheels for the past 10 years. Even 10 years ago when I had dodge duallies, I pulled the chrome simulators off and sported black wheel underneath. I'm not of fan of any chrome vehicle parts. For me, it's just hard to clean. I think it's also more of a generation thing. My uncle gives me heck and vice versa.
Different generations, different fad followings. :nopity: I'd say: "I have chonies older than that", but I'm afraid it might be true. :crackup:
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle.    What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
