My Wheel Project
Spurshot
I live in southern California. It is the birthplace of most vehicle fads. Aftermarket accessorized vehicles are as common as toenail fungus. We all follow fads. Some more than others. It's all personal taste evolved thru emersion in the fads, in the end, especially with something as ubiquitous as a car/truck wheel. Most things related to styles that are retailed are all about fads. Wheels very much included. I've seen wheel fads come and go over the last 4-5 decades and have my personal taste pretty well established. I just can't get into black. It just looks ... blaaah-k to me.
Got it. But, I don't like the ghetto look of 20's on a 4x4. These are my choice for my ride.
Im not a black wheel guy but if anythings "ghetto" its fake bead locks, lol.
  • Replies 62
It's kinda like fake race cars. We all have em.
i like them. im the kind of person who thinks after market rims look stupid, but i got some 22's from the dealer that i totally love, and those look pretty good compared to your stock ones. i think a white truck needs some black to offset it some and make it stand out, just like a black truck needs some chrome to bring other elements to its color. i think thats why my black looks so good with the big 22's.
Looks good Spurshot....I like them.
I bet that truck rides nice with that extra sidewall on the tires and those King shocks. Enjoy!
I like them; it looks like they did a great job with the chroming process. I know you were toying with the idea of coloring the beadlock ring. What about just coloring the bolt heads for a subtle look? If you don't like them you could always change them.
I like em, I also am not a black wheel fan (There are a few on high performance cars I like), but other than that it looks like people are rollin around on steelie snow wheels all year esp if they are matte black, my opinion, different strokes for different folks. You'll have to post pics with them on the truck, i think they'll look really good.
Great choice Spurshot. What are the wheel specs? Are they going to stay tucked in there or stick out a little?
The wheels look great all chrome. I am also not a fan of all black wheels. But since you are looking at the beadlock rings for the wheels I would think the only way it will look right is if they were either black, gunmetal gray, or chrome. Any other color will not look right IMO.
white with black rims looks amazing IMO
Dangerdick was kind and skilled enough to color my pix to see what a colored rim would look like.
have you looked into plastidp?
ive used it a little but most the parts i did in it i ended up swapping out for something different anyway. but it turns out really good, they have gloss and metallic colours now, you can buy all chrome and blast the lip of the rim in white then in a few months peel it off and run full chrome.
im going to plastidip my bumpers in black this summer, and if i dont pick new runningboards ill just black those out too.
personally, im a big fan of the murdered out look.
check out this stie for the colour options, if i would have kept that cts longer i was going to do the lip on the rims white.
http://www.dipit.ca/
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
