OEM AUX Coolers- Location?
My truck comes with the Z82 trailering package which according to my vin and RPO codes should have an aux engine oil cooler and A/T fluid cooler. I just cannot seem to see them any where. I have no desire to take things apart but would like to store the info for later if anyone can advise the correct location. Thanks.
Z82 Trailering equipment, includes trailer hitch, 7-pin and 4-pin connectors
WT - Includes (G80) locking rear differential.
SLE- Includes (G80) locking rear differential on 2WD models. Included with (GAT) All-Terrain Package, (NHT) Max Trailering Package, (PDA) Texas SLE Value Package or (PDU) SLE Value Package.
NHT Max Trailering Package, includes 9.76" rear axle, (GT4) 3.73 rear axle ratio, (JL1) trailer brake controller, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs and increased RGAWR
SLE - Includes (G80) heavy-duty automatic locking rear differential on 2WD models (already standard on 4WD models) and Z82 Trailering Package. Requires (L83) 5.3L EcoTec3 V8 engine. Not available with (Z71) Off-Road Suspension Package. Includes (UHN) 18" X 8.5" bright-machined aluminum wheels with (RBX/RBW) 18" tires or may upgrade to (RD3) 20" aluminum wheels with either (RC7) or (QSS) 20" tires.
SLT - Requires (RBX/RBW) 18" tires or may upgrade to (NZM) 20" chrome wheels or (RD3) 20" ultra bright machined aluminum wheels with either (RC7) or (QSS) 20" tires. With (L86) 6.2L engine, requires (NZM) 20" chrome wheels or (RD3) 20" ultra bright machined aluminum wheels with (QSS) 20" tires. Not available with (Z71) Off-Road Suspension Package.
KNP Cooling, auxiliary external transmission oil cooler
WT, SLE - Included and only available with (L83) 5.3L EcoTec3 V8 engine.
Std on SLT
KC4 Cooling, external engine oil cooler -- STD on all trims
Do these chassis also have the trans oil coolers integrated into the radiator? Can you trace the lines...??
