I also bought the auxiliary switches for my 2016 Chevy Silverado 1500. I hooked one wire from one of the switches up to the 86 terminal on the relay. The 85 terminal is connected to the positive post of the battery. When I flip all of the switches, nothing happens. Did this happen to you?
I’m telling you email smcgillis10 he will make you the relay/fuse box you need .. he really helped Me out .. very knowledgeable dude ..
Need some help,
I have the cargo light, T/C, and 4 aux switches. I have routed the buttons out to the engine bay. I have connected a... relay box (one relay box per switch). Currently each relay (12V, 30A) is set up as such
Battery -> fuse-> relay pin 30
switch(aux) -> relay pin 85
light bar -> relay pin 87
Ground - > relay pin 86
with these connected as such the lights on my switches turn on and do not turn off no matter what.
When I push the switches the light bar does not turn on. I have switched things around but have gotten nothing.
any insight would be appreciated.
Did you hook it up to aux 1? If that doesn’t work, try a different switch. The aux switches are ground controlling. You need to hook the 85 pin to the positive post of the battery, then the switch to the 86 terminal.
  • 5 months later...
I have upfitter switches peddles/tc/cargo lamp/park assist/ldw/hdc/running boards and I configured my switches swapping out hdc with an aux . The hdc (aux) is a non functional switch no wire present I would like to have it function as an on and off switch how can I go about achieving this
On 3/17/2016 at 6:08 PM, arkiehou02 said:
Thanks. That helps out. I am just going to tie the pedal up and down together as the switch for that button. That sounds reasonable. It won't have an indicator but I plan on using it for RGB halos that I want on all the time. But I still want the capability to turn them off. I will use the NO function on the latching relay and the button push will turn them off.
I know this is old but hope you get it lol.  I did this about 5 years ago and only used first 2 aux for lights.  Now i want to use another and i was reading this over again and I am wondering if i did the indicator lights wrong.  I do have it all working I use one latching relay for the relay to the light bar and another for the indicator light.  So thats 2 for each switch. I have 4 hooked up now.  This does work,  But i see you say here to hook up the indicator to NO function and it will turn on and off with the switch .  Does this work for you?  I would help me out as I would not have to add another relay just rewire what I have
On 4/26/2018 at 4:17 PM, TinkeringFox said:
I just tested an Upfitter switch with a CNG button (23146445) and it seems to be identical to the one with TC,Cargo,Exhaust Brake (23145163?). The output and indicator input use the Exhaust Brake plug (X2). If you were to use this CNG switch, or the Exhaust Brake switch inyour application you would need to remove terminal/wire 4 from the X1 connector (main plug) and swap into pin 4 on the X2 connector (exhaust brake plug). The terminals are a different size so a cut and splice would be necessary or just replacing the terminal. This would allow the use or triggering of HDC through the Output pin from CNG or Exhaust Brake. You would just pop on an HDC cap in place of CNG, then move the CNG cap to say Aux 4 to use as your slip tank Trigger.
How can i get pin 4 & 5 to work like AUX 1 & 2 did?  The exhaust brake doesnt work like them.  There is 12v+ initially, then when hit it it goes to zero volts.  I dont know what CNG is but all i need it to do is turn on a latching relay when pressed, then turn off the relay when pressed again.
So i guess no one is watching this thread anymore???
I’m watching but I have no idea what you need to do to achieve what you’re looking for.
lol, well thanks for replying... I dont know what to do, Its like these two switches are reversed polarity for what their function used to be I suppose.  But if i reverse the polarity to the harnness (which i am only using it for AUX 4)  it may screw up the indicator light which is working fine.
What i need is something to reverse the polarity before i get to the latching relay, because everything other than that works fine.  I thought there were others here that got the exhaust brake swithc working for something else other than that function...
  • 10 months later...
hello everyone. i am new here. recently i just bought a 2017 gmc 2500hd denali fully loaded. however, the truck is already in the shop. the ? i have  are these switch panel small enough that i can possibly retrofit ( custom fab ) into the roof console using the sunglass compartment to make it look factory etc, any help would be awesonme. but i need for sure a momentary switch. and couple of latching switch. i ordered all on board air kit with train horn and airbags for it. but i have no space avaible on the orignal switch panel since this truck is fully loaded with all the goodies
   I don't have any pics of mine handy (not on my usual computer, with my vehicle info), but I know some guys have put rocker switch panels into their roof consoles.  Even the big rockers like these:
AMAZON ROCKER SWITCH PANEL
This style of switch has a rear depth of 1.43".    So there is at LEAST that much clearance up there.   But you may have to bend the spades a bit to accommodate the female terminals on your wires.
bump
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
