I would not compare the fox 2.0 to a 5100.
5100 digressive, non rebuild-able, zinc coated brushed metal finish (corrodes fairly quick in extreme weather)
fox 2.0 progressive, rebuild-able, billet aluminium, zinc plated double clear coated
I wouldn't compare them either just based on price. A pair of 5100's for the front only costs $180.
A new eibach spring as well, in addition to a larger diameter shock body. I think a fair comparison is the 6112 to fox 2.0...the Fox 2.5 and icons and kings are in a different league.
I guess when you compare the fact that they are both 2.0" shocks, and the price for the hardware/top mount and eibach springs, they are similarly priced. To me the fox are much more appealing. I think that bilstein should be selling their 6112's assembled to. Making the customer use their stock hardware and top mount is kind of a slap in the face for the price they sell for.
So what I am gathering is Bilsten 5100's and the way they are developing the 6112's so there is no need of installing an aftermarket UCA... Have I come to the correct conclusion or would I be better off buying a new UCA? I would be using the stock 20 inch wheels with 275/60/20 tires...
If you raise, you'll always be better off with a new UCA. However, the Bilstein 5100 and 6112 will be designed to work perfectly with stock UCA's, as is the Fox 2.0 except for those with aluminum stock U/LCA's
Crap so that means if I would buy the 16 AT with the aluminum UCA's when the 6112's come out I will need to replace the U/LCA's. Dang. I was trying to avoid that...
No, you misread. The Bilstein's both 5100 and 6112 will work with stock control arms. You would likely benefit some from getting new UCAs, but it is in no way necessary
If anyone is interested I have a brand new in the box set of Pro Comp SS struts for sale. I purchased these with the intent to install but decided to go with the Fox 2.0 set up.
These are adjustable just like the 5100 and have pretty much the exact same ride characteristics.
I purchased for $210 and will sell for $150 shipped.
http://www.4wheelparts.com/Suspension/Pro-Runner-SS-Monotube-Shock-Absorber.aspx?t_c=1&t_s=90&t_pt=3306&t_pn=EXPZX2108
What's up fellas i have a quick question I bought a 2" kit for my truck to level it with the rear I wanted to know what would be or preferred size and tires to go with
Thank you
I wonder why fox makes the 2.0 different for the aluminum suspension. do their coils come in contact with the control arms some how? Only difference between aluminum and steel arms is the ball joint tapers.
Edited by projectsummit
This has been discussed in length, I have a thread on here that explains the differences between the two arms.
The 6112 is pretty much identical to what comes on the Tacoma & 4Runner Pro Models. The Tundra PRO has a different one-off shock which has a reservoir on it, while the aftermarket Tundra 6112 does not have one.
Does the 6112 for this application have position sensitive valving like the Tundra Pro shocks?
I think the 6112 is a 2.5 diameter shock at least thats what I'am reading.
Edited by southern_sierra
We were talking about comparing the 5100's to the fox 2.0's
The 6112 will not require new arms, but it is always a worthwhile upgrade.
Your posts are not very clear, so I am not sure what you are referring too.
The Fox 2.0 is a 2" Diameter shock. The 6112 is a 2.65" Diameter shock. The 5100 is a 2.0" diameter shock.
The Fox 2.0 and Bilstein 6112 come with new springs, the 5100 does not.
From over a year of testing the 6112 and from personal experience with both systems, the Fox 2.0 are no where near the performance level of the 6112, but are a big upgrade from the 5100, which is much better than stock.
The cost is very reasonable for what you get, a 2.65" shock that costs half of all of the other 2.5 options out there. If you want a billet top hat, threaded shock body and all that race level awesomeness you should be looking at a Fox, King or ICON 2.5" coilover system.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
