NNBS Auto Headlight Question
Hi, My lights come on all the time even when its daytime. I prefer just to have the drl's on instead of everything on. Could my sunload sensor be bad? Also is there a fuse i can check for the circuit? Is it difficult to replace?
Thanks.
Well, i have no direct knowledge regarding it, but my gut tells me the sensor in the dash is shot. Could be a fuse, so I would check there first. Replace whatever fuse(s) that handle that circuit. If results the same, you know where that leads you.
Double check that there isn't something covering the sensor on your dash. Had that problem for about a day on my previous truck and somehow never noticed that I had something covering the sensor just enough to turn on the lights.
