Not everything that gets tested gets released.
Just because it's being tested now doesn't mean that the intended release is for 16 model.
I agree, It would appear there will at least be a power increase with the Duramax Engines in 2016-2017.
GM really needs to introduce 4500 and 5500 cab and chassis models. The F-550 and Ram 5500 absolutely kill GM's top 3500HD cab and chassis models. GM really has no reputation with commercial truck users anymore, it's like don't even bother with a Chevy or GMC if you need a 'real' truck. Strictly receational trucks now.
I know, there are all kinds of rumors on the internet that heavier GM trucks are on the way, but there is not one single shread of hard evidence GM is even considering such models.
Hell even the Ford and Ram 1 ton duallys crush GMs 1 ton duallys.
The Ford matches the GM while the Ram has lagged behind for years...
Biggest problem is with the commercial chassis/cabs. Best GM has is 13,000 GVW, while Ford and Ram go to 19,500 GVW. Can't use a GM truck for much.
The Ram 4500 just took the truck of the year status for that class of vehicle. I guess GM doesn't feel there is much of a market to tap in to and justify the R&D expense to develop a competitive offering.
More is not always better. If the truck is in commerce a 19,5000 GVWR leaves room for 6,500 GVW trailer until a class A might be needed. The 13,000lb GVWR gives a little more breathing room. From an insurance, tax, licensing and compliance, and hiring drivers standpoint that can be a big deal. Getting a guy a Class B if it's needed isn't a big deal, insurable Class A drivers are in short supply.
http://special-reports.pickuptrucks.com/2014/08/2014-ultimate-hd-challenge-one-ton-overview.html
Ok so the difference is not as much as i was thinking, but still behind.
Pretty sure in certain conf. the Ram can tow up to 30,000lbs
The problem is the GM dually's have outclassed the Ram in real world tests towing much less weight. If the Ram can't keep up with GM or Ford towing 20,000 lbs how do you think that truck is going to handle 30,000 lbs?
A full minute slower. Goes to prove that the impressive marketing numbers do not always play out the same in the real world. Substantially more HP and Torque for the 6.4 Hemi in the Ram, yet it got skunked by the lowly 6.0L in the Silverado. Thanks for posting the link!
But then, this is same thing in heavy commercial trucking. Impressive numbers do not always mean one will get to the top of the hill quicker. My lowly 12.7L Series 60 Detroit shames other newer engines with larger displacement on a regular basis with the same loads.
Might not want to wait till 2016. GM is chopping the warranties down.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
