Sorry didn't see that post before I hit send. It's got a 7.5" lift on it with 20x10 -12 Fuel Mavericks mounted on 37"x13.5" Toyo MT's
Do the tires rub at all? I'm thinking of doing a 6 inch lift on 35s, but with the same offset, and wheel size.
Here is a couple pics of my new addition
Started with a 2004 Duramax with 8"s of lit and 20x12 -44 with 37x13.50x20 Nitto Mud Grapplers and traded it in on a 2015 Chevy 1500 and added a 4" Fabtech with 20x10 -24 and 33x12.50x20 Nitto R/T's which was a huge mistake and now I'm back in a 2016 2500HD GMC SLT Duramax with a ready lift leveling kit and 22x12 -44 KMC Wheels and 33x12.50x22. Just ordered some Cognito UCA's and Fox Shocks to go on all 4 corners.
I must say I like your truck the best out of all these because of the cleared headlights
This is my 2006 2500 6in lift with torsion bolts taken out. 20x10 weld Cheyennes on 33x12.5 nitto trail grapplers. Soon to put same size Terra grappler g2 on before this winter. I can try to get more better pics later
Traded off my 2014 High Country this week for a 2016 2500 Duramax. I pull a trailer nearly daily for my business and the poor 5.3 was going to die an early death if I kept it much longer. I loved the High Country, but being a work truck I decided to go with a step down to an LTZ this time. Pretty much all the same stuff minus the collision alert and sunroof, neither of which I really cared about anyway. My dealer is top notch and before I ever even picked the truck up I had them put 5% tint, leveling kit, steps, B&W turnover ball, and 305/55R20 Toyo R/Ts on it. Definitely a huge difference in towing my mowing trailer and I can't wait to hook up my camper and car hauler to it.
New truck...
2016 3500 duramax, 295 70 r18 mastercraft cxt, n-fab steps, husky x-act liners,du-ha under seat storage, pacer cab lights, 2 1/4" ready lift leveling kit.
post-161949-0-79372500-1476838044_thumb.jpgpost-161949-0-30731400-1476838106_thumb.jpgpost-161949-0-37550400-1476838192_thumb.jpgpost-161949-0-73384300-1476838201_thumb.jpgpost-161949-0-92162400-1476838211_thumb.jpgpost-161949-0-96945800-1476838220_thumb.jpg
Edited by Danny m
attachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpg
Do the tires rub at all? Thinking of running a 285/70/18 and cranking the tbars up 1 inch
Hasn't rubbed once in the first 1000 miles Edited by Danny m
What did I do my Silverdao today? I had the GM dealer installed a GM Tonneau cover and the local car spa / detailer wax the truck with simoniz diamond plate ceramic paint coating. WOW ! I'm loving it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
