How does it tow? I want to do a lift and people warned me about how bad it would tow. Looks like you have my mother in law in the back. (Justnkidding)
It tows well. It towed it home just fine. It was wandering between 4th and 5th around 65mph. I have 37s and with the 3.73 it’s terrible. Once I go to 4.88 it will be much better. It was actually very stable. I towed it home about 4 hours without stabilizer hitch and sway bars. And with semis blowing by it barely moved the truck. I tow with my truck a lot. Car trailers loaded down, utility trailer with atvs and stuff. Never had an issue. Once the gears get done, it will tow a lot better. I’m on 7.5 inch lift, 37s and 20x14 wheels.
I have a 2017 L5P. I’m not sure of the gearing. I really don’t want to make it a bad experience. I rub with my my 35’s. I’m only looking to go up 4-5 inches (which is probably 2-3 more in the front.
You have a diesel, so tow wise totally different animal. If you lift it and keep the same size tires, it won’t tow any different than it does now.
On 6/27/2018 at 4:36 AM, b-garage said:
Sorry, I do not, and I do not own this truck any more. Being on the factory wheels the tires were pretty much flush with the body.
What did you think of those Kanati Mug Hogs? I just put a set of 285/70 17's on my 2008 FJ Cruiser and thinking about getting some 295/70 17's for my 2015 2500HD. So far so good on my FJ, but curious how they'll do on a bigger heavier vehicle like my truck.
I can’t  say a whole lot. I only had them on my truck for about 10k miles. They were a little noisy, not as loud as others I have heard going down the highway though. Didn’t have a chance to try them off-road either. I raised the front by cranking on the torsion keys. It rode like crap with the stock tires on it like that. When I put the Kanatis on they did seem to soften the ride quite a bit. For 10k miles, they did not seem to be wearing out fast either.
I liked them well enough that I bought 7 more to put on my Dually that I traded the black truck for. I had to go with the next smaller size, but I am really impressed with he ride quality on the new 3500. And I cranked the torsion bars on it as well. Only have about 1500 miles on the Dually so far.
I daily drive my hd on a set of those tires and they will need replacement in less than a year.  Otherwise performance is fine
I am new to the Diesel 2500 scene so here area couple pics of my 2016. I have installed a bed liner, leveled the front end 1.5 inches, bug deflector, bed cover and nerfbars. I will do a delete when the warranty is up as it only has 27,000 miles on it. Oh ya going to install 285/70/18 tires soon. Need something a little more aggressive.
Edited by 426power
heres mine! love this truck. Came from a 10" lifted 1500 2014 silverado. So glad I went with a 2500 this time around.
Edited by jerseytaylor
Very nice upgrade! What's the lift/wheel/tire setup?
I just took a look at it, it has Zone Off-road upper control arms and front shocks, (didn’t see level kit/torsion keys) Fuel Boost 18” wheels and Toyo open country 35x12.5 a/t’s.
Sold my 14 Sierra 1500 and replaced with this 15 2500. The headlights and taillights I kept from my 1500. They are 17 1500 Denali lights.  Also if anyone is interested in the white fender molding/trim PM me. I plan on selling or trading it for the standard black
Edited by zmnypit
On 6/7/2018 at 10:56 PM, m5guy said:
Nice.  Looks exactly like the truck I bought over the weekend except mine will be pulling a 15,000lb, 40' toyhauler.
I've been on this forum for a while, so I guess it's time I posted a few pics of my 2015 2500HD. Nothing special, but I like it.5b5426088937e_Frontpass.thumb.jpg.1b6eb40055b93282b9710d49474d491a.jpg
5b5425f541761_Frontdriver.thumb.jpg.d64a7227ea500f8174f73ab309ce30fd.jpgFront.thumb.jpg.9fca6f85c9aa54e6638746e202b7497a.jpg5b5426760c44c_Rearpass.thumb.jpg.e836a639bf8e6ae5c591c976bb1b15ba.jpg
It’s all about if you like it not if anyone else does. Nice clean looking truck, tires are a nice upgrade from stock. What is road noise like on these?
I just got them yesterday and only driven about 25 miles, but I haven't heard any yet.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
