Bought a mistake I think, need help!!!
Hey guys I'm new to this forum and really need the help. I can turn wrenches but I am new to the v8 and chevy world. Anyway I bought a 1997 k1500 4x4 5.7 vortec with 153,000 miles on it. I bought the truck with the ses light on and knew it was a bad o2 sensor (bank 1 sensor 1). Anyway I replaced it by 154,000 and not even 100 miles later the ses light came on again. I scanned and retrieved a code for the other o2 sensor on the passanger side manifold befor the cat. Before I could get around to fixing it the light went out so I figured all was good. Within the span of 3 weeks the ses light has come and gone maybe 2-3 times. But today on way to work (30 miles) the light blinked and then stayed on.....Also (I've learned its a commen problem) the 5.7 seems to "knock" when I start in morning, or after my 10 hr shift. Doesn't do it if I run to Walmart or anything just after it sits. Is there a way to fix the noise without going "balls deep" into the engine. I love the truck and payed too much so I'm stuck with it. Anyway I don't know what I've gotten myself into, and I'm afraid I may be screwed.
Welcome to the forum, that sucks about your truck. I know the later 5.7 Vortecs were bad for intake manifold coolant leaks. How's the coolant level in your rad. If there's coolant leaking into to your oil that could contribute to the knocking. Or if the coolant is being burnt some how and coating the O2 sensors that maybe why there throwing codes. Just a thought.
from my experience a transient CEL/SES is fairly common among older vehicles, even with low miles. My 2000 camaro had the same problem and it was entirely determined, it seemed, by the temperature outside.
It really makes your heart sink when that light comes back on when you've fought to get it to go off, moreso when you have to have it off to keep your car on the road because of inspections.
I'm wondering if the knock you're describing is piston slap? I know this was VERY common in late 90s/ early 2000s vehicles and would occur pretty much any time the vehicle was cold. It sounds very bad, but its not as bad as you might think on the engine. Basically in the case of piston slap its because of the different metal types and expansion rates used in the engines. They compensated by making the pistons "too small" iirc.. which made them "knock" in the cylinders until everything warmed up and they all became the same temp. I could be wrong here tho.. I know this for a fact on LSx engines, but a 97 still had that TBI iirc.
My buddy said something about lifter noise because hydraulic lifters idk haha. Anyway the truck is now miss firing bad and the check engine light blinks 8 times every now and then. I'm gonna take it to the shop and just pay to have someone knowledgeable to figure it out, don't have the money but i figure I need it so.....oh and my mpg sucks haha
Yeah a blinking light means a cat-melting misfire - basically fuel going right out the tailpipe instead of making power. That's why your mileage sucks. Could be any number of things on OBD-II ...
TBI's last year was '95 - no OBD-II vehicles were TBI, just FYI. If it was TBI it would still be running without a problem ... and if there was a problem it would be a simple, & cheap fix. OBD-II ended all that in the name of emissions ... :sick:
Like someone has already posted, piston slap was a well know problem back then. It actually sounds worse than it is. That might be your knock.
Well if he's got a rough idle and hes burning up o2 sensors from dumping too much fuel..
TPS? MAF? The knock may still be piston slap but that goes away when the engine warms up. What DOESN'T go away is valvetrain noise. But that's not really a knock. More like a "rattle."
There's several kinds of "knocks" in motors, it could even be as simple as a pulley thats out of round. Ya know early LSx motors (and even more recent ones) had an issue with the crank pulley being press fitted together and as the rubber broke down the pulley would wobble. Could be something like that?
I'd say you should do some simple maintenance yourself on the truck, won't cost ya much.
clean the tps, clean the maf, clean the IAC change the air filter if it's not fairly new, clean the TB (I dont know how the pre lsb post tbi throttle bodies work, but on lsx TBs you get a lot of grime on em that can make them stick and mess with your tps and IAC) Pull your plugs and check their condition/gap, have your fuel filter changed. I HIGHLY doubt any of this will fix your issues, but its good to do, especially if you dont know how the previous owner took care of the truck and/or the last time this was done.
They didn't have piston slap problems in the old 5.0 and 5.7 small blocks like in your 97. Piston slap didn't come around until the LS motors like the 5.3 and 6.0's...from 99 and up. You may have a bearing noise. That may sound serious, but my current 97 5.7 has it a few seconds, less than a minute on cold start ups, and so did a previous 5.7 truck. Those motors are still going strong, and will probably outlast the trucks they are in.
Yep - the 5.7 is legendary. Reliable as a stone ax when you factor out all the '96-up electronic emission crap. Same with the Ford 5.0/5.8. I've got the 5.0 in our '86 Grand Marquis with 220k miles on it. Boy does it RAP LOUD on the first fire of the spring after sitting all winter long draining oil back to the sump. After 11 springtime start-ups it's amazing it still has bearings left! THAT'S how you build an engine. :thumbs:
The more I think about this, the more deja-vu I'm getting after working on my buddy's '96 Tahoe. I ended up throwing in the towel after my buddy threw THOUSANDS of dollars into trying to make this thing run right, and it still insists on being a 6 cylinder instead of a V8.
Here's a vid of when I first got it running after it sat with the oil pan and timing cover off in my buddy's barn for 5+ years ...
(searching for the vid - thought I had it ... I'll update when/if I find it. You can clearly hear the spark knock as it idles like a diesel ...)
Replace both of the sensors before the cat. Heating element is probably gone
It's telling the computer wrong info for fuel/gas on cold temperatures
It's telling the computer wrong info for fuel/gas on cold temperatures.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
