Going Led Crazy
No more under the hood light, door courtesy lights and inside foot lights that come with the new
2015 Duramax 2500HD even when you get the LTZ z71 and all the Bells and whistle package :bs: So I added my own + some.
Under the hood lights that come on with a mercury switch when the hood is opened.
Led Cargo and backup/reverse lights.
Led Bed cap lights that give more light than the stock under the rail led's.
Under the side step lights that come on with the reverse lights and with the keyfob when the doors are unlocked.
Under the door courtesy lights that come on and fade out with the dome lights + the added more foot lighting inside.
Very nice, interesting how you tied everything into the pickup, thats a great idea tying it in with the dome lights and door locks
I hope you have an Optima yellowtop battery lol.
No need as led's suck up very little juice + its not like all the truck lights are left on all the time.
We have used the cargo and bed lights for a couple hours at a time when we go night shooting and never had a problem.
This carport has 600 led's that suck up much more juice than the truck and I have left them on all day
with a 12 volt lawn mower battery hooked up.
Love it man. I did my own bed and back-up LED also. Where did you tie in the door and side step lights to come on? I've been wanting to do that one bad but can't find any decent guides
The side step lights are wired with the backup led lights so they all come on with the keyfob when you unlock the doors or put the truck in reverse.
Both wired at the trailer hitch plug trailer backup/reverse wire.
The door lights are tied in with the dome light grey wire on the block under the dash,far left drivers side.
Under hood lights haven't been on the trucks for over 16 years
Ryan
Ryan
Took my truck in for its first service and recall power steering clamp fix, when they opened the hood a tech guy called over another and then another lol.
The truck became a show and tell soon after and most that looked at it started talking that led lights under the hood should be a standard on all trucks.
The side step lights are wired with the backup led lights so they all come on with the keyfob when you unlock the doors or put the truck in reverse.Both wired at the trailer hitch plug trailer backup/reverse wire.The door lights are tied in with the dome light grey wire on the block under the dash,far left drivers side.
Nice thanks. Do you have any pics of the install or where you hid the wires?
Also did you find a particular Silverado LED kit or just use generic that fit? I have used Oznium in the past always had good luck with them
The led's for the doors I wired front left door through the rubber boot between the body and door
into the door and down to the led's.
The left rear door wired under the door sill with the factory wiring to the rear door then up into
the boot to the door and down to the led's.
The right side doors the same except wires from the electrical box are up under dash across to the right side of the truck then the same as the left side.
All wires are in a soft flexible tube so I don't need to worry about any shorts from a raw wire later almost like the factory stuff.
The led's under the steps and for backup are wired from the trailer hitch wiring (reverse/backup wire) through plastic wire conduit from the rear following the factory wiring along the frame to each step.
All conections are soldered and shrink wrapped except the door Led' as I used plugs for them as you never know when you may need to remove a door panel that the led' are on.
All Led's are purchased on fleebay, do some research on what led's will work for you needs and the look you desire before you make a purchase.
Cob led's under the hood and under the bed cover like these http://www.ebay.com/itm/221421797594?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Led strip lights for under the doors and steps like these http://www.ebay.com/itm/201188329184?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Do research on the leds including the strip led's as there is a few different light colors of white and the amount of light
each will produce.
The 3M tape that comes on the cob led's works well but the tape on many brands of the strip led's I have played with
not so good so plan to get some 3M double back automotive tape or good silicone glue.
  • 3 weeks later...
Nice work.
Where did you get your Bedrug and how do you like it? Is it durable and good for heavy use (furniture, large objects, heavy objects, etc.)?
    Paul Annabelle
    Paul Annabelle
  • Who's Online   3 Members, 0 Anonymous, 1,448 Guests (See full list)
