Cold air intake
I've been looking into getting a cold air intake and a throttle body spacer for my 2011 5.3 Silverado. Although I have heard the throttle body is pointless with a vortec but not quite sure how this works. And also is it worth it to buy a k and n cold air intake or is there a way to make my own cold air intake Becuase I have heard of people doing that thanks in advance for any answers or help
The spacer is a ripoff on just about any modern engine, it won't do anything.
As for intakes, the one that has been proven to get the biggest gain is the Airaid MIT. This is just a tube that replaces the stock unit and retains the factory airbox. Blackbear did this test a few years ago.
Buy a ported throttle body at least you get some added responsiveness
Ryan
I second the airraid MIT, for about $125 well worth it IMO
On my old s10, I tried different cai setups. I couldn't tell any difference in performance or mpg. With that, my Silverado air intake is stock w paper filter. I wish the MIT was cheaper than $125.
If you are looking for simply a cold air intake, your truck came stock with one. Take a look at the stock air box, I don't think it pulls air from the engine compartment. I know it does pull air from behind the headlight though. If you are after the noise, then you need to dump the stock air tube. Stock comes with some fancy bends and baffles to keep the noise down by using resonance.
This, though i'm still back and forth on whether or not i want to commit to a full fledge CAI. Though the MIT is certainly more economical and is better price/performance wise by a mile. I'm wondering how it sounds with the Airaid MIT? I also like the thought of keeping an enclosed airbox so heat from the engine under the hood isn't affecting the Intake. I've found volant for about the same price as Airaid but 400$ is still a lot when 600$ will get you headers.
I'm not an engineer but I'd think the bulk of the sound gain is from the new tube not having the silencers, not so much the open element filter. It gave my truck a decent growl but I already had exhaust done too.
I did not notice any increased sound with the MIT on my 2014, which is in stark contrast to when I had one on my 2013.
The MIT is the one with the filter and a less restrictive tube is it not? Or is that the Junior?
MIT is tube only. They offer it with s filter too though. Junior adds the filter.
Think i'm about to order the Jr kit this week. Since i'm going to commit to headers, catted Y-pipe, and exhaust the CAI isn't really going to effect sound too much for that setup.
  • 2 months later...
Adding a k&n replacement filter on most bikes I have owned did increase intake noise, and on my buddys fj1200 it introduced a thumping noise under the fuel tank(where the air box is). Put stock filter back in, noise is gone. On my truck I went with the volant, but after a month of loud intake noise, I sold it off, put stock box back on, and about a month later I replaced stock filter with replacement panel k&n filter. There is slightly more noise.
On the 2000 GTP I had, I changed the pulley and installed a SLP cold air intake on it. Intake noise was louder than any small block chevy 4bbl engine with the air cleaner lid flipped over was. It also un muffled the supercharger air flow as well, adding a loud whine to the intake noise.
All those bends, and additions of alternate air flow paths to the intake tube screw with the resonance enough to stop it. Does the job so well that GM and Ford both have had intake tubes running into the cabin to give the driver the intake noise that pedestrians don't have to listen to.
As stated already , throttle body spacers were only helpful when the MAF was in the throttle body or when the throttle body houses the injectors. It has since become the equivalent of just about anything Billy Mayse sold at 4am. (God rest his soul)
I am a HUGE fan of the MiT kits, same HP gains as ANY other CAI on the market with out the growl of the Drowning Wookie coming from under the hood. modern GM truck air boxes flow very well, it's the huge intake runner tube muffler system that is restricting
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 845 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
