Remove chrome surround from silverado headlights
I've called several body shop and paint places and everyone refuses to color match the chrome on my truck. I've been able to purchase GM paint to match or prepainted parts for everything except for the chrome around the headlights because all I've found for part numbers is the whole headlight assembly. I want to try removing the chrome surround and either through sanding or chemical means, remove the chrome and see if a body shop will paint them. Has any one removed the chrome surround and can give any pointers?
GM does have a paint to match bezel lamp coming but it is not available yet.
That would be great if they did, did you hear that from the dealership ?
Could you buy an unpainted work truck headlight surround and have that painted?
I would love to, but so far looking through all the part diagrams I can only find the headlight as an assembly.
tape off lights and plastidip them....not only is is something u can do urself, its cost effective and worst case u can remove it if u hate it...im considering it myself
Something like that lol. They will be out when the new Custom Sport, and Midnight Z71 trucks start showing up as they have black or white bezels on them, which in turn, results in the offering of a paint to match headlamp. The only thing, is the bezel is still only serviced with the lamp and can't be purchased seperate.
I remember when I worked at my uncles body shop he was the same way his shop would refuse to paint chrome parts and also textured plastics as paint will peal off the chrome no matter how good you prep it it'll never last and that textured plastic is iffy stuff as well. Maby try getting them decal wrapped.
There are a few places that will plastic dip or wrap so I want to try them. I don't know how well they can match the ruby red paint though. I was thinking about some anzos, but I checked their website and the bulbs are h7 and I already have h11's in hids for the stock projectors
I agree with the texture plastic, on 2wt I got the bottom grill piece that was black texture plastic colored matched white. It looked great at first but now with rain and dirt etc, it looks really faded and I can't clean it very well. One time removing it the paint chipped cus I bent it a little to much. Plasti dip is your friend, I just did my front and rear bumper. That trim piece now looks different so tomorrow I'm redoing removing it and dipping it. d3e4459c24ff75baf60f040cbdc8a718.jpgd28abc3626152d362d43f49835eb73c1.jpg
Put them in the oven at like 260 for about 15 minutes. The chrome is held on with clips and 3m tape. The heat will loosen the tape so you can pry it off. Pry from the side of the light that touches the grill. Pry gently.
    C. Hart
    C. Hart
  • Who's Online   5 Members, 1 Anonymous, 587 Guests (See full list)
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
