New guy!!
Txjose
First off hello everyone my name (obviously) is Jose.
Just got a smashing deal on a 2014 silverado double cab Z71 4x4 so i couldnt resist. This is my 2nd truck as i still own a 2005 colorado crew cab that has been lowered and modded pretty good. Its got the 5cyl but on a 125 shot of juice bolt ons build 4L65E aluminum shafts built rear blah blah blahhhh....
So i just got my 2014 yesterday and im already going to lift it amd go 33s....i can say that this forum alone is going to make me spend a LOT of money lol...
The truck was purchased because i needed something 4x4 for the ice and snow for work since work is in North Dakota.
Im on mobile but i will post some pics later today or tomorrow after i level it and get 33s...ive had low trucks now its time to be in the sky!!
Thanks guys!!!
Btw my fiance has a 2014 silverado as well just a silver crew cab 2WD and mine is a white double cab Z71 4x4. We are just waiting for the call for us to get our leveling kits installed and my 33s!!!
thanks for the welcomes!!
here is a pic of my fiance's silver 2014 2WD with pro comp lvl and 275/60/20 BFG Ko2s and my 2014 4WD with the same lvl and 33x12.5/20 (305/55/20) mastercrafts
his and hers 1
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
