Ring Gear Hum noise, AGAIN!!!
So over the weekend my ring gear starting humming again between 60-65 mph. Ive had this issue addressed once before when I had 5,000 miles on my truck. Now I have 12,000 and the noise is back. I brought my truck today to a different dealer (around the corner from my office) for an oil change and they are opening up a "Case File" with GM. While filling out the paperwork at check in the service guy asked if there were any other issues or noises they needed to look at while in there. So I told him. I told him I wasn't ready to leave it with them for an extended period of time this week but wanted to get the process started to get this problem fixed again.They are keeping my truck today for some test with the head service guy for the dealership.
Can anyone tell me what all this entails? Ive never heard of a Case File or had to bring in a vehicle for an issue more than once for that matter. Is this something the dealership does because the issue was not resolved by a previous dealer and is no big deal or is this more along the lines of a lemon law protection issue for GM?
Am I in for a battle to get this resolved?
Thanks for the help.
Hi EPIC CAJUN,
To clarify, a case file is a permanent record which documents the interactions a GM employee has with a customer regarding his/her concern. Creating a case allows our internal resources to further review the information that has been provided. If you would like me to contact your dealership to further discuss your case, please send us a private message.
Thank you,
Kayla K.
GM Customer Care
Based on the noise its currently making. Sound is identical to the noise it made last time when the dealer replaced the pinion and ring gear. Im sure it can be something else thats humming/whining but it only makes the noise when you are a a steady speed with foot on the gas. If you let off the noise stops. Its instant on and off with the gas peddle.
  • 3 weeks later...
I just purchased my new 2015 Silverado in February, and it started making a noticeable humming sound whenever the truck is over 40 mph and my foot is off the accelerator. I checked to see if it could possibly be the truck changing form 8-4 cylinders but that wasn't it. Have any of you guys experienced this problem? The dealer has the truck in for servicing and the "loaner" doesn't make that sound. both trucks are 2015 crew cabs, same engine, same tranny.
Based on your description, the noise is definitely caused by differential gears. I have seen them make noise when only under load, and also only when coasting. It all comes down to improper backlash setting and shimming of gears. sometimes using higher viscosity gear lube like 80W140 helps quiet down the noise. however, they only recommend higher viscosity lube for hotter climates or for heavy loading of the differential, such as towing.
Sounds like you have the same issue as me. Does it only make the noise at a certain MPH range? Say 40-44 mph and only when foot on the peddle? Thats what mine was doing when I had the pinion and ring gear replaced. The dealer said the 8 (i think) bolts around the ring gear and the pinion backlash both were way off from spec. It actually took them two attempts at getting it right where the noise was completely gone. So this will be the third attempt at the fix.
12 bolts should be holding the ring gear to the carrier. GM usually makes them so the number of bolts to hold the cover to the axle housing is the same as the ring gear bolts
Gotcha. Its been a while since I looked at the paperwork so I couldn't recall how many bolts it stated.
Mine makes as whine when I'm coasting in drive to a stoplight. Both of my 14s did it so I'm assuming it's normal. I have 100k drive line warranty and I'll probably have a new truck bore my 5 years or 100 is up. Nothing I'm loosing sleep over.
  • 6 months later...
My symptoms are a little different. The humming is consistent with speed. Acceleration or deceleration have no effect. It can be heard above 30 mph and is loudest at 45 or so... Still hums at higher speeds but can't really hear it as much due to road noise. I have a 14 with 48k miles and I'm furious about it. It's going in on Monday, my birthday, happy birthday to me!...
Sent from my Nexus 6 using Tapatalk
One of my trucks whines around 50 mph. Playing with the throttle makes it start and stop. Whines when you let off the throttle. Grandpa's 56 Chevy whine was louder but it never came apart. Miss that whine and grandpa! Still remember putting gas in through the drop down taillight.
Well, it isn't exactly normal because most properly assembled differentials are quiet, but in a mild case it will not hurt anything. I talked to a Nissan tech about this same issue years ago and some older Nissan Z cars had a noticeable rear differential whine. Nissan tried to quiet the differentials by recommending thicker viscosity rear end lube, like 80W140 instead of 80W90. This works well for hot climates, but not for winter weather up north because the oil gets too thick. My 1995 Nissan truck had a slight whine in the rear differential when coasting only. It did not get worse over 70k miles of so I put on the truck after they replaced the original differential which whined only under load, causing more annoying steady whine. I tried the heavier lube as suggested, and it did quiet the differential a little, but it seems to hurt my fuel economy a little in colder months.
Truck is in today. They think it's wheel bearings. It is covered under power train warranty. Fingers crossed.
Update: was not covered but they split the cost with me... Had the seat shim and wheel bearings done at the same time for 225.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
