2011 Silverado LED turn signal install
hey there, Ive been trying to figure out the install for the LED front turn signals on my 2011 Silverado. I have installed resistors a few different ways, all of which tend to hyper flash in the end. I have a pair of 50w resistors and a pair of 25w resistors. Ive tried many different combos of the two and still can't correct the hyper flash. Ive 50w wired in at the main connector and 25w at each of the bulbs, seemed to correct hyper flash when sitting idling using turn signals, however as soon as i would drive the truck it would hyper flash. Ive also tried "stacking" the resistors per another post i found to which i wired them both in at the main turn signal wire (blue w/ white stripe) and grounded them to the radiator core support, this seemed to correct my hyper flash again until i drove the vehicle and it would hyper flash right away. Im completely lost here and could really use some help with this. Its such a simple concept however i just can't get it right. :confused::confused::confused:
Hope you get it worked out. I just got LED's for my interior and they were direct replacements for the standard bulbs. I wasn't sure how others would work, I never had anything but standard bulbs in my pickups.
Sent from my crappy iPhone 6
using Tapatalk
Can't you find a 'plug n play' type LED bulb that would be a direct replacement for the factory 4157NA?
using Tapatalk
The bulbs you want ARE out there, on the packaging they will say "with CAB Bus", they are truly "plug & pray" :)
thats good to know, i didn't know you could purchase LED bulbs that had everything built in. However my issue still lies in that I already have everything (bulbs and resistors) purchased and "used" because I've tried installing them. So I'm hoping to get help working with what I've already got.
