Another New Recall, N15203 15203 REAR BRAKE LINE BRACKET
Service Update Bulletins N150203 15203 REAR BRAKE LINE BRACKET BOLT TO REAR AXLE LOOSE - * EXPIRES W/BASE WARRANTY * 06/09/2015 Open
So if anyone is getting close to their base warranty expiring, you might want to schedule an appointment. Not sure what trucks, years, and assembly plants this covers. My truck is a 2014 GMC SLE Double Cab, assembled at Ft. Wayne, in August of 2013.
I didn't know anything about it until I took my truck in for an oil change today, and it looks like they just opened it up on the 9th of June.
Just wanted to give you guys a heads up, since I haven't seen this one on here yet
#15203 - Service Update for Inventory and Customer Vehicles - Rear Brake Line Bracket Bolt to Rear Axle Loose - Expires with Base Warranty - (Jun 10, 2015)
Subject:
Service Update for Inventory and Customer Vehicles — Rear Brake Line Bracket Bolt to Rear Axle Loose — Expires with Base Warranty
Models:
2014-2015 Chevrolet Silverado LD
2015 Chevrolet Silverado HD
2014-2015 GMC Sierra LD
2015 GMC Sierra HD
2015 GMC Sierra Denali LD
So, is it a recall or a bulletin?
I'm gonna guess a bulletin. It's just a bracket. I'll climb under the truck and check it out tonight myself.
It said recall on the service order. Then it used bulletin in the description. So your guess is as good as mine.
Recalls are non-expiring and can be issued at any time. This does appear to be a "Bulletin", and I'll ask my dealer about it when the truck goes in for its first oil change.
I can't find any reference to it anywhere but here.
Brought my truck in for the 5th time for the vibes and they addressed this recall on it. It says recall #15203 rear break line bracket to rear axle loose. They inspected the bracket bolt, set to 18 ft lbs and retorqued the bolt. BTW the vibes are worse than when I dropped it off.
I don't know the particular VIN codes that relate to the particular locations... however...
Look for a sticker on the jamb of the driver's door as that may give you some info. Additionally, I believe the CC trucks are built in Mexico while the DC trucks are Fort Wayne, IN. I know my DC as an IN truck.
New owner here, how do I find out where mine was built?
Mexico only builds crews
Fort Wayne builds double cab and regular cab.
Flint build HD's and can (possibly) flex to 1500 dc/cc.
It MAY be that if it is an NHT (max tow) truck that it is built in Flint. (perhaps those with 2015 max tow's can check and let us know.
Position 11 in the VIN gives plant location:
F= Flint
Z= Fort Wayne
G= Silao
socialmedial ? You sure that's right?
Also, if you email someone, your "return email address" is already included... Why do you have to tell them again?
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 1,056 Guests (See full list)
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
