Thinking of replacing shocks/struts
I have a 2014 Sierra crew cab with the All Terrain package. As noted the factory "Rancho" shocks are not Rancho at all, in that regards they are dismal in performance so far from my experience. I had about 300lbs in the bed this weekend and hit a mild dip in the road, shocks blew thru the travel and bounced off of the bounce bumpers.
So with that I am thinking of changing out and going to the Bilstein socks on all 4 corners. Truck is stock other than I had it leveled in the rear via drop shackles, so which series would be the best bet. I am not looking for a couch/Cadillac ride, I want a firm sporty ride but I also don't want the back end of the truck moving across the road like it has the few times I drove over wash board asphalt.
So what says you to the folks who have replaced their shocks?
Thanks.... Todd
I'm running Bilstein 4600's on all 4 corners and have been very happy with them-best $300 I've spent so far. They're a pretty good balance between a nice ride and enough rebound to keep the truck controlled, responsive and not floaty. My factory shocks seriously lacked low and high speed rebound. I obviously did not have Rancho's stock, but if history tells us anything it is that GM spec'd shocks are pathetic.
I've got the billy 5100s they are a big improvement over the ranchos. You can tell more so off-road than on the highway, I've had several friends comment on how nice it rides around town.
-Skeet
Well spoke with Bilstein, going to measure the rear shock length now as the truck sits. Mine is lowered 2" in the rear so the tech thinks the 5125 series will be better for the rear since they can find one that will work with my truck.
How many of you installed yours? How bad was the front, I am assuming I only need a spring compressor for the fronts?
I had a shop do mine, I got the leveling struts so I'm not sure if they're different than a regular strut. I know they did need a spring compressor.
-Skeet
I've got 5100s front and back that I installed myself. Pretty easy job with a good spring compressor.
If you want to step up in quality a bit, a shock that would work for you is the Bilstein 5165 Series, part # 25-177510 . It has a collapsed length of 14.4" vs. 16.2" for the replacement 5100 so you don't need to worry about bottoming out and it's a bit nicer shock all the way around. The 255/70 valving is firmer than the 5100 so it gives very good handling. I'm running the #25-187717 which is the same thing only longer (stock to 3" or so of lift). Both have longer travel than stock. Mine are paired with ICON coilovers in front and they seem to work very well together.
If you want to use these you'll need new bushings (BSN-2202G) and spacers (BSN-E4B4660R1), four of each. While it can be done by hand with a vice, I'd recommend having a shop press those in. I also recommend getting the billet mounting kit (11176015), two of those as they're nicer than the hose clamp deals.
I put in Rancho quick lift and love them. Just last week I was in Dallas for business and rented a car - got an LT 2015 Silverado. It did not ride nearly as nice as my 2015 with adjustable front/rear quicklifts. Very pleased with my ranchos...
I'm thinking about replacing my shocks, I have 22" wheels and the oem shocks just don't get it. You feel every little bump rut you name it. Had bilsteins on my 05 GMC HD and loved them
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
