Opt7 led lights
You may not need them. Try taking the drivers side flip adapter off and try again. Also, the capacitor harness had the wires wanting to come out if the plug. Make sure they're pushed forward. There were times I had to unplug the main wiring plug going into the headlight (on my Silverado, Idk about sierras) and plug it back in and then turn the light switch off and on. And make sure ask the Lloyds are actually chipped in good. I thought mine were but you could just pull then right out with ease
Alright got the headlights figured out. Any advice for getting the fog bulbs to clip in?
  • Replies 204
Opt7 fog bulbs are 5000k but i dont think the color is that big of a difference. I mean if youre looking for it then youll notice but i dont think if someone who didnt know dod the ocassionaly glance would be able to tell the difference
I tried searching the past week or so for 5000k headlights so that they matched the fog but the only option i ever found was hid and thats not what i wanted
That I can't help... I havent done mine yet. You can't get the plugs to clip together?
the factory wiring connects to the LED bulb but the bulb won't clip into the fog housing. Pain in the butt
obviously making sure the notches line up properly. Make sure the O-ring doesn't get pinch in the setting. and Push in on the tabs/clips so they reach the appropriate snap in point. This are the things i noticed when i switched my fogs. And as Rkeeper said I've heard a lot of people say they the o ring needs some vaseline or grease
Here are pics of Opt7 LED headlights and opt7 CREE fogs. As you can tell, the alignment of the headlights is pretty far from perfect and the fogs have been rendered effectively useless now that they have been replaced by LED. Any suggestions on how to fix the alignment of the headlights? Also, where is the screw located to aim the headlights up or down? I'm new to truck modification
IMG 3984
Before
IMG 3989
LED Headlights.... Curve up slightly on each end.
IMG 3988
With fogs. LOL
IMG 3989
Another just LED headlights
Before
With fogs. LOL
There's a hole on the topside of the headlights in the engine bay.. Youll see a plastic screw in there. How about a frontal pic with lows and fogs?
All sierras 14 and 15 have projectors. I have them in mine
Just curious.. Did you have any alignment issues with the cutoff after putting in the LED headlights?
With fogs. LOL
Is the picture with the fogs, just the cree fogs? or both headlights and fogs? So the opt 7 cree fogs are pretty bad, huh?
As far as what? Like up and down or alignment of the leds?
