Opt7 led lights
Mainly alignment but maybe both. I put the LEDs in the way that the stock bulb would have fit but the cutoff isn't straight anymore.. The edges curve up slightly just curious
  • Replies 204
heres a picture i took. Its not that great becouse of my workbench but you can see the cut off. As far as the led alignment, theres only one way to put them in im pretty sure.
Already sent mine back. They're junk. I had too much foreground illumination and not enough throw. My H9 upgrade worked better.
Would you mind posting a picture of your h9 mod's output? Thank you!
My opt's get here friday. Gonna attempt to throw them in after work before heading to pick up a friend at the airport. Have a cpl hours before they land so hopefully my lack of skills self can get them in quickly. Will get to see them perform asap since thatll be night time.
Have these coming along with some led cargo (921) and license (194) bulbs coming all on same day
Junk as in not any better than the dim sierra headlights? Should I not waste my time?
I must be slow ... i cant get these damn things to come on.
Wouldnt plug directly in so i used the adapter and they still wont turn on
Are you using the capacitor and the polarity flip harnesses? Make sure they're actually plugged in all the way
i dont have a capacitor but i have the polarity harness. Ive pushed everything as hard as i can
The capacitors should jabber came in the same box as the polarity flip harnesses
The one on the left?
The capacitors should have came in the same box as the polarity flip harnesses
Sent from my SAMSUNG-SM-N910A using Tapatalk
