Odometer and Hour Meter - Where is data stored?
Current owner of a 2004 5.3 Suburban. Looking at a 2005 Sierra HD Duramax with a branded title for mileage discrepancy. I've confirmed the odometer mileage is not correct and I understand the mileage is only stored in the cluster. So there is no way to find the 'real' mileage number. Way to go GM.
Does anyone know if the actual engine hours might be stored in an onboard computer?
I'm interested in purchasing the truck, but need to get a handle on either hours or mileage with some degree of accruacy.
Thanks!
Only stored in the cluster
Scanned today with Snap-On Solus Ultra - it showed engine hours readout from ECM. It showed mileage from cluster. I know mileage isn't correct, as I've discovered two spliced wires in cluster harness and and found a hidden rocker switch - assuming this was ODO kill switch. Trying to get a handle on hours so I can make an offer - or pass.
I was reading something a while ago that said if you have the amount of hours and multiply that by sixty, that will give you an approximate of how many miles are on the engine. You figure a 2004 driving 15K per year should have around 165K miles today, multiplying the hours by sixty may give you an idea of how many miles is on that truck.
If that truck has a tampered odometer I'd run.
I know, I'm headed that way. But....if I can get a comfort level with accuracy of engine hours and pick it up for way below book, I'm sorta interested. I'm having a local guy that does a lot of duramax fleet work look at it. His advice over the phone, 'you'd better get it a price low enough you could throw $10K in it and it still be a deal'.
If the odo has been tampered with, I'd be extremely concerned as to what else has been messed with. It's one thing for the odo to die but to intentionally turn it off... I have to second the run away idea.
Ya it's one thing to have the cluster go out and have to put another one, but it's a totally different thing to see that someone actually tampered with it. I honestly don't care how cheap you could get it, there's other D-maxs out there that you can get and not worry about how everything might be.
Don't count on the EH hours to be accurate either.
How can the ECM hours be off? As I understand it, the cluster reads hours from ECM, unlike mileage which is only logged in cluster.
Nevermind: Just read that a number of issues can cause ECM to reset - one being batteries disconnected for an extended period.
And you have no idea if that is the ECM that came with the vehcle
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
