Black or Chrome Center Caps on Hyper Black wheels...
Luster, is it not obvious what my choice would be?
Total Stealth.
Total Stealth.
I must add that your vette is the nicest convertible one I have seen. As good as it gets!
I wasn't really sold on the Vert, but when my wife said... "That's the one I want!", it was hard to say no. :thumbs:
I totally understand that!
BTW since your somewhat local to me, end of July I should be selling my SEY's if you happen to know anyone who wood want them.
I am looking for Black GMC center caps for my 22's if anyone has any laying around or know the part numbers for them......
Heres mine to give you an idea.
Truck got dirty today on a jobsite.
Love these wheels. Would be nice if they offered color matching center caps.
I would go black, then have them color match sprayed at my paint shop.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
