Bluetooth Question 2015 Sierra
The 2500/3500's did not get the 14/15 1/2 ton style sheet metal for the 2014 model year. The changeover to the new styling did occur for the 2500/3500 were in production long before the normal Jul/Aug factory changeover -- and all new style HD's were labelled as 2015 model.
At the summer changeover, the HD's got many of the changes that the 2015 1/2 tons received. The forums have used the 2015.5 description to indicate HD's that were built with those changes.
Summer factory changeover is normal - this is the first time I've heard the 15.5 tag applied to 1500 series. (and i
Don't mean to hijack the thread but when I try to connect my iphone 5s to my truck a message comes up on my phone saying there is a problem with the gmc intellilink system. Funny thing is that as soon as I get into the truck and start her up the message says my phone is connected. Not sure why when someone calls, it doesn't work and my phone just ends up ringing...
Blutooth is turned on, on my phone.
Anyone know what the issue could be?
There were some changes midway through 2015 production I think. Added text ability, cool pitch and yaw screen on dic, and switched to capacitive touch screen. That's all I can think of for sure. I know there was a known BT issue for the newer 15.5 trucks that gm fixed.
What is a '15.5? I didn't know there were changes that warrant the ".5". Or are you just trying to tell us that your truck is REALLY new?
15.5 included changes to many subsystems including the HMI/RADIO etc If your vin is FF5XXXXX its a 15.5
That makes sense, I wasn't aware that there were changes made to the 2015s. I thought those changes were between 2014 and 2015, which led me to believe that anyone that said 2015.5 is just trying to tell us that their truck is really new since there are no differences between a 2015 made in September of last year or July of this year. What exactly are the differences? Is there a list somewhere?
If there were changes to the 1500 during '15 I haven't found any and I did what I believe as a pretty good search.
And these were the changes from 14 to 15:
GMC Sierra 1500
Deletions
(G56) Stealth Gray Metallic
(GTS) Cobalt Blue Metallic
New Features
Next Gen OnStar (UE1) including (VV4) WiFi communications equipment and Mobile Internet Connectivity. Note Next Gen OnStar drives a slightly larger exterior antenna and is molded in black.
(DQS) Mirrors, outside heated power-adjustable vertical camper, memory equipped, upper glass, power-folding and manual extending, chrome. Includes integrated turn signal indicators consisting of 51 square inch flat mirror surface positioned over a 24.5 square inch convex mirror surface with a common head and lower convex spotter glass (convex glass is not heated and not power adjustable) and addition of Auxiliary cargo lamp for backing up (helps to see trailer when backing up with a trailer) and amber auxiliary clearance lamp
(CGN) Spray-on Bed Liner now available optionally on most Sierra models & cabs. Includes GMC logo on front bed wall
Off-Road graphic in Driver Info Center for all Z71 and All Terrain models
USB Jack in glovebox of trucks with AZ3 bench seat
(G1K) Stone Blue Metallic: available on all Sierra and all Terrain
(G7J) Emerald Green Metallic available on all Sierra (previously available as promo color)
Changes
(IO5, IO6) 8 inch radios now available on SLE Regular Cab models (replacing IO3 & IO4)
(UVC) Rear Camera now included with (PDD) Sierra Convenience Package on 1SA Sierra model
(VLQ) Chrome Tow Hooks become factory installed option
HD radio feature removed from all radios
Hill Start Assist hold time increased to 3 seconds (from 1.5 seconds)
(L86) 6.2L V8 to become available in early Q4 (not available at start of 2015 MY production)
E85 capability on 4.3L (LV3) engine or 5.3L (L83) engine with RPO (FHS)
(GAN) Quicksilver Metallic no longer available on All Terrain
(GAZ) Summit White no longer available on Sierra 1500 All Terrain
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
