Yes, I understand the equation and the relationship. What I'd like to see is a 350w inverter. This would allow for about a 3 amp outlet, which would be adequate for that 18v charger that we talked about earlier. Yes, this would be about a 30 amp load at 12 volts. Assuming the inverter is behind the socket in the dash, and the wiring being no longer than 8-10 feet routed (probably less),10 gauge wire could be used. I know copper is expensive, but it would be nice to have something a bit more powerful.
I understand that never will everyone be happy. So, you have to draw the line somewhere. Largely, I don't believe these outlets even get used. The fact that I'm -already- paying for something in my truck that is of no value to me is irritating. Having to pay even MORE for heavier duty wiring and a larger inverter would be even more irritating. I get what you're saying, but I (and MANY others) don't want to be paying for features that only a handful of people actually need or will use. I would much rather this not be present AT ALL and buy an aftermarket inverter to plug into the accessory outlet.
A really small laptop. As I mentioned earlier, a high performance laptop like the Alienware can't even be on, and charge at the same time on this outlet.
We all understand that it's for light, intermittent use. But at what point is it useless? I think that is the point I'm trying to make. It's useless. Just a marketing gimmick.
Here's the real question of the day... Who the hell still uses a portable DVD player? Even 2 year-olds and grandparents use iPads now.
Yep. Understood. The bigger laptops have the higher current draw adapters. That's largely to be able to supply enough power to charge while also driving the large screen.
The example of a portable DVD player was generic. :)
The Ford F150 has a 400W inverter, is Chevy not capable of the same engineering? if not, I guess we should swap to Ford.
Ford Website: "110-volt/400-watt Power Inverter "http://www.ford.com/trucks/f150/trim/lariat/viewall/
It amazes me how many otherwise reasonably mature people have temper tantrums like a 3yo over such petty stuff. Really? You're going to dump your $40k plus truck and buy a -FORD- because of a $30 accessory you can buy in a parts store? Honestly, I wish more people WOULD jump ship for reasons like this. GM would cut their pricing to win people over, and in doing so, might even pull some of these useless accessories out of the truck altogether. That would make the truck lighter, it would get better MPG...
Yes. Please go buy a Ford. There's no downside for anyone, really.
The Ford get better gas mileage...and is lighter...
And it has rear seat vents. And a real AC inverter.
Still wouldn't own one. Lol!
Fords are barely lighter, if any. The 700 pound claim they use is bull. Realistically maybe 2-300 seems about the norm when comparing similar trucks. And mileage isn't that much better in the real world.
As for the outlet, if availability of a more powerful AC outlet is a deciding factor, more power to you.
While I am not surprised GM put as small an inverter as it can get in there so they can claim the outlet as a marketing checkmark, I am surprised they do not offer a "workman package" option that upgrades the inverter to something much more useful to charge or run bigger stuff. A workman being able to charge Li-Ion tool batteries between jobs is useful. Its obviously a bolt-on item, and running heavier wire is easy in the manufacturing process. It looks like they do that depending on the radio options. Maybe a future option..
Really small laptop? Both my MacBook Pros have/had 90 or 95 watt power bricks and my tank of an HP from work it the same. I'm sure there are some that use more juice but they're gonna be the exception to the rule.
The 5.0 in my 2012 Ford work truck gets almost the same mileage I am getting out of Silverado, about 18 to 19 mpg in the summer. I was hoping the cylinder deactivation would get better real world mpg's than the Ford 5.0 but in my case it doesn't. I will say IMO that the DI 5.3 power curve is quite a bit better than the 5.0. I am glad this thread got started because I just assumed the AC outlet would power most small electrical items but now I am going to test my air pump and a few other things before I got camping or to the drive in.
The popcorn popper will be too much. :)
Not caring about the wattage of the outlet, I have not had a single problem using mine for anything I have plugged in it. I charge my laptop, a battery charger and a small emergency air compressor. The A/C outlet seems to work perfectly for its designed proposes. I'm not a carpenter with my truck on a job sight but if I was I would have inverter installed and hooked up to the battery if needing to run high powered items. Or use a portable generator.
Okay. Here's the equation:
P=VI (Power (watts) = Voltage (volts) x Current (amps))
With the numbers provided above, the available current (I, in amps)
should be...
I = 150/12 = 12.5 A
Yes, I am a physics nerd.
That's at 12 volts input. Divide by 110 volts output gives you 1.36amps at 110 volts which isn't a whole lot. It's designed to run computers etc.
Even the outlet in the Tacoma bed is 400w. Plus you only need the heavier guage wire to the inverter, not to the plug. The cost wouldn't be that much more....
Edited by bmf4069
  • 5 months later...
  • 6 months later...
I'm going to assume that I cannot plug in our 30a to 15a adapter to connect our travel trailer power to that plug and run the AC? :)
It would be nice to have a 400 W power inverter or come standard like the ford does
Edited by f8l vnm
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 590 Guests (See full list)
    • Atlas,   Then following your logic we can't believe any story that the MSM produces? I mean it's documented they heavily donate to Democrat candidates. Vote Democrat in high percentages. Many MSM talents are married to Democrat politicians, Gov. employees. That goes for on-air and off, personalities and reporters. So they would all be biased and nothing they produce is to be believed in your mind?   Again the article simply was about ways AI can be used for pricing products. Nothing discounted current situations as a factor.    Again keep looking through your left/right lenses. I don't live my life that way.   And as a heads up this thread will be cleaned up again as much of this is off topic and is receiving
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
