Best Muffler Swap?
clayc213
What do you have to race? I have a 1248HP LS 1977 280Z, 150HP Softail Harley Davidson. 200 HP Hayabusa, 2014 Silverado RCSB, oh and my wifes Honda Pilot! LOL Im ready!!! :crackup: BTW I wasn't trying to rough you up with my comment.
RT
My experience with Magnaflow 12909 on my truck has been positive. Deeper tone than stock and little drone on the highway.
May just suit your needs based on initial post.
RT
Ha! Its all in good fun! I want to take on the honda pilot! I also want pics of the 280 NOW!
I know it's a pain to navigate, but there is an entire thread with feedback on K2 muffler swaps, deletes, and catbacks. If you want no drone and V4 your options are limited. If you can accept drone and/or turn off V4/AFM your options are wide open.
agreed. I did the muffler delete and left in the V4 butterfly valve but it still sounds awful in V4 mode. I have to keep it in M5 driving around until i get on the highway.
I will take some this weekend for you at the track, Hope it doesn't rain us out.
RT
I was wondering if anybody has put a glasspack instead of the straight pipe from a muffler delete. But leaving the valve?
I swapped in a single SpinTech Super Pro Street 9000 I had lying around from my 04 GTO. Not too loud. I love the sound. Very throaty when you get on it and as soon as you're off the throttle its extremely quiet. I'll try to get a clip up soon.
Here is a quick video leaving work. Only could go about a quarter throttle cause tires will just break loose. My little Eco Poop killa
Let's compare, I have 100% stock cat-back
https://vimeo.com/137073048
Sent from Off Driller Side
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 693 Guests (See full list)
