No problem. It's been the same for atleast 3 different platforms now I believe.
thanks...like i said its my first truck thats been my own so since i picked it up a month ago i have been spending hours reading watching videos, reviews, etc but every now and then i get some conflicting information but i come here and get it straight pretty quickly.
thanks again man!
sorry guys i am a complete newbie to trucks and sierra...
i cant get a straight answer on my bolt pattern? i have a stock set up. 2014 sierra z71 SLE....i am not sure if it i am looking at metric vs standard but it is very conflicting.
anyone know what the stock bolt pattern is???
6X5.5" which is the same as 6X139.7mm Some rim mfg use inches, some use metric.
My 2016 Sierra All Terrain with a Traxda 2.5" leveling kit. Stock wheels with 275/60R20 BFG AT KO2's. It looks awesome in my opinion.
  • Like 5
We seem to have the same opinion.
7.5" RC, stock wheels, 35x12.5R18
I assume that's a knuckle lift and with 18" rims you had to run spacers to keep your rims from hitting the UCAs? Nice truck.
2.5" RC and 305/50/20 Nitto Terra Grappler G2s
Those wide tires not hitting the UCAs or Sway Bars while turning?
No sir, not at all.
Lookin' good!
hey guys so I have 17inch stock wheels..i am looking to run a 32inch tire on my truck. My questions (forgive me I am new to owning my own truck) but would I have to recalibrate the gears, speedometer or anything? I have read increasing wheel size can cause certain things to be off...
Don't worry about it...32 is real close to stock size. You will be off a little...check the numbers here: https://www.tacomaworld.com/tirecalc
When you start getting to 34+ is when you have to look at regearing and speedo calc.
No sir, not at all.
Interesting...I have 275/65r18 on those same style stockers (+24) and have less than 1/4" clearance at full lock between rubber and my UCAs. I'm not even sure that 285s won't rub.
Do you have Amps on the second picture? I like the running board delete look.
That was in between steps. I had just sold my stockers. I now have goRhino RB10s. You can see them in my sig pic.
edit: maybe your issue is 18s where I have 20s, I dont know, I just know I don't rub on anything at all full lock....
Edited by techsan15
I can attest to this, it is close but all I rub is the liner slightly when at full lock.
2" level, stock wheels, 305/55R20 Nitto Terra Grappler G2.
Word...Doesn't make sense that you (bcbz71) are rubbing the UCA with a 275 unless you have aftermarket UCAs which state not to use stock wheels. Aftermarket UCAs usually need 4.5-5" worth of Backspacing...
Long story short it doesn't make sense lol
Edited by techsan15
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,375 Guests (See full list)
