Finally got one
Last Thursday I finally found the GMC that I wanted.
A black Denali, 6.2 crew cab short box with black rims and interior. Sort of a truck version of my Corvette.
This truck is awesome and I can't wait to get some miles on it!post-147906-0-03850700-1442950567_thumb.jpgpost-147906-0-69936400-1442950644_thumb.jpg
What a nice combo! Congrats!
I could not deal with up-keeping two black vehicles :lol:
Yeh, I am starting to get the shakes every time the breeze picks up and starts blowing up the dust :crazy:
Two very nice rides!
Thanks!
Only thing I would recommend is getting 20% factory tint on those front windows - just did mine for $75 in about an hr on my SLT and it looks light years better. What kind of tonneau cover is on there?
Yes, I should look into getting them tinted -is that something you can get from GM or is it aftermarket and where did you get yours?
The cover is the GMC factory soft folding. It opens up nice and easy and comes off just as easy if needed. I know it isn't a secure cover if someone wants to cut it to get in, but I figure if someone really wants to get into any cover it's not too tuff.
Yeah spending a lot of time parked in Philly I am targeting the BakFlip brand or something similar with a more "hard" cover.
I actually drove past a place on the way up to the dealer picking up the truck and asked for a quote based on the tint I had on my old enovy, guy told me to come back the next day and he would do it in 45 minutes. Like I said, $75 for both front windows and it just looks a lot sleeker with the black truck - also cuts down on the sun in your eyes significantly, and keeps the truck cooler. Dealers might do it, but it will cost more, and I would rather go to a place that specializes in tinting and does dozens of vehicles a week, for better quality work.
I did the TN legal tint which is 35% but the windows already have some tint to them anyway so I think it is more like 30%. First mod I did for my black truck!
Super sharp truck. Did you buy it off the lot like that?
Thanks!
Yes, there was a dealer in the area that had 4 black and a few other colors. This one was just about exactly how I would have ordered it.
It was the only one that had ever seen with the 22" black rims and all terrain tires -plus it was the only one with the 6.2.
I dont know that ive ever seen a gm dealer offer tinting services. The back oem glass us actually tinted glass and not a film. I had my front 2 tinted at a local tint shop with 3m brand 20% and it matches quite nicely. You may want to check state laws on allowed tint darknesses. My state is 32% but i opted for the 20%. Ive had 20 on all of my cars and never had an issue, but not sure how strict it is in NY tho. Btw, beautiful truck and vette!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
