DEF Tank Removal
Are you going for the Weight Saving's mod now :D?
Took mine off too, did you take the filler neck out too?
I left the filler neck for now, may take it out at a later time.
With the tank removed and the Exhaust swapped out, truck raised like an inch...lol
Amp steps go on tomorrow...
sounds like you took it off for good ,can you reprogram this engine to run normal with out def?
Programmed by PPEI. Runs better than normal! Way better!!!!!!!!!!!!!!!
  • 3 weeks later...
As long as you don't want powertrain warranty.
(and it's technically illegal to mess with emissions, but so is driving 5 over)
