No, I didn't replace the bearings. They seemed fine when I was inspecting them. I did replace the seals though. Does yours have the rear end shake? My shake was coming from rear end and I never felt in the steering wheel.
Yeah I got the rear shake. Had it running on jack stands and I could see the left side wheel doin a dance. Switched wheels and same thing.
Sounds like a problem with an individual not the brand. Welcome to the forum and good luck with your truck. I have been a GM fan for many years and have never experienced this vibration issue on a new truck. Some of my older vehicles have had vibration at higher speeds but always fixed with tires & balance. It wasn't too long ago when 8 ft. box's were the most common sight. Now they stand out. Any pics?
Individual?
Service manager
Yes the service manager was fired for unknown reasons.The dealership ended up going through GM protocol steps and eventually something to do with the front end was inspected and replaced(bushings).Has improved significantly,sad to say the vibe ration is rather minimal now.But still present.I just ordered new 18" aluminum wheels and will be having them mounted next week along with new tires.Hopefully this helps.Most likely purchasing Firestone destination A/T's.Have to be much better than the stock steel wheels and 17" Bridgestone duller tires.Crossing my fingers!
Service manager
2015 Chevrolet
Crew Cab
5.5' Bed
5.3L
6-Speed
3.42
70+ mph
Solutions: Driveshaft rebalanced, roadforced balanced all 4 tires, & front end alignment by independent shops. Better but still there.
Replaced both rear axles shafts with Yukon Gear axles, vibration free since
So I guess everyone is changing their axles. I ordered these on 8/23 and they are back ordered to 9/29.
Hoping these cure my shakes.
Axle shaft 22943112 for the 9.5" diff $376 list each
YA G15812663) Yukon gear @ Summit racing $256 each.
Sent from my SM-G935V using Tapatalk
2014 Sierra
Crew Cab
5.5 Bed
5.3L
6-speed
3.42
74+
60,000 miles
Drove about 1,000 miles this weekend and with speed limit at 70MPH I was in the speed spot for the vibrations. Do not feel it in the steering wheel as that is rock solid. But the seats are shaking bad and if you put your head against the head rest, you'll get an instant head ache. Definitely notice it between 74 and 82 mph.
Going to be ordering the Yukon Axles and Bilstein 5100's and will report back.
Tried new tires, RF balance, rotations, alignments... nothing helps. Appreciate all the information so far in this thread on axles :thumbs:
2017 Silverado LT
CC
SB
5.3L
6-speed
3.42
68+ mph
4000 miles
So my Vibration wasn't as bad as some of the videos that I have seen posted where the water in the cup was shaking all over the place. It also did not make any audible shaking sounds, but I could feel it. I noticed it on my first long trip with the truck and thought it might be a bad balance on the tire or something.
I took it to the local chevy dealer and they ran the picoscope on it. They confirmed that it did have a vibration.
It had a 15.3 mg Tire 1 vibration @ 14.1hz. They replaced the steering gear bushings and said that I had a defective Passive Exhaust Valve and installed a new exhaust from the Cat back.
They ran the picoscope again and the amplitude was down from 15.3mg to ~3.5mg at 14.0hz.
I have only had one short highway trip and it feels a little better. I will report back when I get a good run at highway speeds.
Thanks to everyone who has contributed to this thread.
Edited by ScottSilverado1906
2014 Sierra
Crew Cab
5.5 Bed
5.3L
6-speed
3.42
74+
60,000 miles
Hope you have better luck than me getting your axles. I ordered mine 8/23 and still have not received them.
Called today and was told they are back ordered to 11/3.
I used them on my 2014 Silverado with little change in my vibration. Got tired of throwing money at it so got rid of it.
Good luck if you try it.
Sent from my SM-T830 using Tapatalk
  • 3 years later...
2014 Sierra 1500
2WD
Crew Cab Short Bed
5.3
3.42 gears
Factory wheels and tires
New to me purchased with 111,500 miles
Rock steady smooth all the way to 63 mph at 64 there is a hint of vibration.  At 68 mph it is violent with a fore aft surge feel to it.  It does this in Drive, 5M, Tow Haul and Neutral. At 70 mph gets better but still not good.  68 mph is definitely were it peaks.
I suspect the "surge" feel to the vibration it is probably the axles.  I have a driveshaft ready to try but I will pull the wheels off and check the axle flanges first.  I will also check the pinion angles.
I will report back in about two weeks or so when I have some time to do the work.
Hard for me to believe, but it looks like a simple tire balance and rotation at Discount Tire did the trick.
The tires and factory wheels were brand new Dealer installed 12,000 mile before I bought the truck.
The Driveshaft was out of round so I changed it.  But it didn't seem to make much difference, IDK
After driving the truck another 1200 miles and in different (warmer) temperatures the vibration was very inconsistent.  It varied in intensity (usually annoying but not violent like before) and the speeds at which it happened.  Usually 60 to 70 MPH for the main vibration and a barley noticeable bed shake at around 45-47 MPH.
I was convinced it was the Rear Axles, Oh well I'm cautiously happy for now.
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 811 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
