Small Fishing Boat Owners? (Bass Raider, Bass Hunter, etc..)
HiggySTL
Well, I just got a new Pelican Bass Raider 10e as my new fishing "vessel". I had a 2007 Nitro and I sold it because I didn't use it nearly enough as I would have liked to. It just sat in storage and I would go out maybe once every 2-3 years. I am an avid fisherman, but most of the time I would fish with a buddy of mine or my brother in law, who both have boats of their own already on the water. Where I am at, it is a good couple hours to the nearest fishing hole where full outboards are allowed. SO....., I sold my Nitro and got a little two man fishing rig with a trolling motor. It fits in my garage without taking up much space and I can throw it in the bed of my truck and hit all the local fishing holes that are small boat or electric motor only lakes/ponds. So far, I am loving this thing and fishing more now with this than I ever did with a "real" boat. Anyone else here have a similar small fishing boat? I have read up on TONS of mods that can be done to these boats and have already started a few. If you have a similar boat, have you done any mods to it you'd like to share?
I have a couple boats... A depth finder is a cool upgrade, but there's not a whole lot you can do without making it heavy. I'd like to put in a livewell and rod box with power.
Yeah, a depth finder is a necessity instead of an upgrade to me :-)
I went to the Bassresource.com forum and they have around 130 pages dedicated to the Bass Raider. Some of the mods some of those guys have done are really creative. They have added all kinds of attachments, flooring, fishing decks, seat mounts and the list goes on and on. It has become a fun little project on the side coming up with new ideas to build and add to this thing. A lot of the mods take weight into consideration and they make stuff out of pvc and other materials to cut down on the weight.
I really like fishing lights, very convenient since I do some night fishing. In my 14' boat, I have a livewell with an aerator, nav/fishing lights, 2 anchors and the fish finder. With the raised front deck and swivel seats it's a good setup for fishing.
Sounds like a nice set up, that is the next thing I am looking into is some lights as well. Are you running an outboard on it or just a trolling motor?
I have put in a carpeted floor, bow mount trolling motor with a Bigfoot switch, transom mount rudder, fish finder, a couple rod holders and pedestal seat post and floor mount in the front and an 11" seat mount in the back. I like to stand to fish, so a butt seat was a must. May look into building a raised tackle storage area out of PVC piping that will secure in the old seat holder groves. I saw another guy built one and it turned out really nice. This is a good little rig to take my son out to some fishing holes for a couple hours within a few minutes from our house.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
