No it's not.
In 2wd the front diff and the transfer case are not turning.
I believe if you have an electronic transfer case where the knob as an auto function then the front driveshaft is always spinning even in 2wd, at least in auto. Also since the front driveshaft is spinning the front diff will also be spinning just like the rear, but the hubs won't be locked. This is at least how I understand an auto 4x4 system is like.
I believe if you have an electronic transfer case where the knob as an auto function then the front driveshaft is always spinning even in 2wd, at least in auto. Also since the front driveshaft is spinning the front diff will also be spinning just like the rear, but the hubs won't be locked. This is at least how I understand an auto 4x4 system is like.I thi
My understanding is/was that it's the other way around - with the auto system in 2wd mode, the front axles are engaged and the front wheels are driving the diff, but the front driveline is disconnected at the transfer case.
When 'auto' kicks into 4wd it engages at the transfer case to complete the driveline power flow.
Think about it though. It would be a lot less stress on the whole drivetrain if the front driveshaft spun all the time and when 4hi comes on in auto it's less stress and just need to lock the hubs. With an auto 4x4 system it needs to be able to go into and out of 4hi very quick so the driveshaft needs to already be spinning. If it took as long for it to be put into 4hi in auto than it takes if you turn the dial or shift in the floor to 4hi yourself then there would be advantage to auto 4x4. And if it has to get the driveshaft to start spinning then it would take as long as manually putting it in 4hi. In regular 2wd it may not spin, but in auto the driveshaft will spin. It may even spin either way. One day I might look at the driveshaft in 2wd and auto 4 to see for myself, that is if it's not raining.
With the front shafts already engaged, the drive shaft would be spinning, since the front diff would be driving it.
With it connected at the transfer case and the 1/2 shafts disconnected, the drive shaft would be turning, driven by the transfer case.
Either way the front drive shaft and front diff will be turning, hence the auto mode parasitic loss referred to in the OM.
isn't the front diff spinning even in 2wd? It's CV's hooked to the diff. the auto mode clutches are in the transfer case. That I do know.
I still have yet been able to look at mine in 2wd and auto since it's been raining all week. But, and I know they're different TCs, the front drive shaft didn't spin in 2wd on my old '98. I'm just assuming that the front driveshaft in my '14 spins all the time in auto, but not sure about in 2wd so it may or may not in regular 2wd. Plus I'm pretty sure they still use locking hubs which means the half shafts shouldn't spin unless it's in 4x4. Unless they've changed and they have something different in the front diff itself that does the same thing.
With no manual hubs the CV's are spinning all the time, no matter what the Tcase is in. Hence the front diff must be spinning all the time also. I think on my '94 4Runner there was a vacuum hose that ran down the diff, which engaged the spider gears or something like that.. I don't know. I know I saw what looks like a electric motor on the passenger side of our diffs. That might be something that disengages the the pinion so the front drive shaft does not spin in 2wd.
The electric motor you saw was probably for the steering since these 1500s have electronic rack and pinion. Tomorrow I'll be able to look under my truck while a buddy is in the driver seat letting it roll forward so I'll see what all spins in 2wd and auto 4. I'm just curious by now lol.
Yes, you are probably correct! Forgot about elec ps. Let us know man.
Neither the front driveshaft or the half shafts on the front axle moved while in both 2wd or auto. I was expecting one or both to turn at least in auto, but maybe he let the truck roll forward before it finished the switch to auto. So I guess neither moves unless it's in full time 4x4 or in auto when the ECU tells it to put it in 4. So seems like everything is done in the transfer case and they still have auto locking hubs, at least from what I can tell.
As for the OP, I've never had an issue when not using 4x4 for an extended period of time. When I had my '98 the only thing I would do is go to the boat landing near my house since it was gravel at the time and just tested to make sure 4x4 engaged in late Fall for the Winter. For the 10 years I had that truck ('04-'14) I never had a problem with the 4x4 other than 1 time and that was just the switch in the dash that went bad. So never had any of the actual mechanicals not work. And I did put that through hell which included mudding at least 1 or twice a month. As long as you abuse the truck too much and change the gear oil in the axles along with fluid in the transfer case then it should last the life of the truck without any problems. For sure now adays since GM seems to have beefed up the drivetrain in the past few years.
Edited by SouthernSilveradoGuy85
I can't believe this thread is still going. :driving:
The axle is engaged by an actuator on the right hand side. The CV's always spin.
It must be a lot of slack then cause I only had my buddy let the truck roll for a couple inches and neither the half shafts or front driveshaft moved while in 2wd or auto 4. At least that's how it is on my '14.
No. it doesn't spin in 2wd.
The front axles each have disconnect and there is a disconnect at the transfer case.
In 'auto', it will be spinning.
And of course, it turns in 4wd.
  • 5 years later...
On 5/2/2016 at 7:32 PM, FL335i said:
J-Doc. This is my first 1/2 ton 4WD. I've had a lot of toyotas and even a F250. None made the "rubbing" noise you described. But yes, if you are on dry pack, pavement etc in 4wd it will make the "rub" noise. I work in construction, large sites. I use Auto 4wd more than anything. I get the rubbing noise even on some good dirt roads when in 4 hi. But the more you use it the less noise it makes. I'll admit, I'm a experienced rock crawler, SAS'd 4runner, run Detroit lockers and it alarmed even me. Just the way these more modern systems operate. Everything is tighter. I have 44k on my truck and the noise is about half what it was when new. I changed my diff oils this past weekend and tried 4wd today on the job. even more quite. In short... NORMAL. Do not drive on good traction surfaces with any 4wd. Use the Auto 4wd. 4WD is for real-deal sand, mud etc; Loose surfaces.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
