Dash Problems!
14' double cab 1500 Z71 and 15' crew cab 2500 HD nothing to report here..... Both trucks are fine.... Both have 50ish thousand miles.
  • Replies 82
So, I took mine apart, looks like they lied as they never replaced it. I took a heat gun to the back side of the bump and force the bump down slowly with the curvature of my thigh. Moved all the foam padding to where the clips are rather than between each clip. seems to look like new now
I am glad you added this post Morris Lee that tells me I better do my homework and make some sort of marking on the current dash extension and not to mention ask to see the part that was removed to ensure that they indeed replaced it. Thanks again.
I just noticed mine has this at 1000mi during cold weather.
I don't want the dash ripped apart. Would 3m tape behind the bulge hold it in place?
3M tape is not going to hold, if anything, you want less stuff in between to prevent it from pushing up. From factory, there is a foam where the bump is, that is what is pushing it up.
You need to remove the trim piece on the pillers on the passenger side is the handle with two bolts under the 2 covers. After the pillers are removed, you can pry the dash up with something soft so you dont scratch the dash, about 6 to 8 clips if I recall correctly
After thinking about this some more I believe I am just going to try and find some black welting to install in the joint in this area. Done correctly it should look 'factory' and also stick up enough to cover any gaps that would be visible from the front seats.
2016 GMC Sierra SLT Loaded same issue! 768 miles.
South Florida, so temperature not the issue. Coldest night has been 61 degrees.
will bring to dealer next week.
Will let everyone know how it goes for me tomorrow as I meet with my dealer. Mine has been that way since I bought it last month. Hopefully a real solution will be offered.
Sent from my Z987 using Tapatalk
Aubin I wanted to point out that earlier posts also said the dealer lied and never actually replaced the part. My thinking is maybe some of our parts are defective. Time will tell.
Took mine in and the service manager is going to replace both the front trim piece that is wavy and the dash as it has a noticeable hump in front of the passengers seat. Really like how nice he was about it and informative about a few other questions I had. Will keep you posted on the outcome as the parts have to be ordered and the work scheduled.
Mine did not change from upper 60s to the lower 30s....
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
