Headlight Fog Light Consensus
Just bought a new 2015 Sierra Crew SLT, really digging it so far.
OK, minus the horrible headlights. So I've read everything on this forum that I can find about the heads and fogs and I'm trying to get a consensus.
My issue with the lights is that going around a bend I can't see a THING!! I've adjusted the headlights one turn higher as suggested by members here, and that helped with down the road visibility without blinding others, but did nothing to improve side lighting.
I bought a set of LED fogs on Amazon in hopes they would be brighter and shine more to the side. They are brighter, but not in a good way. The light goes everywhere but where I want it....on the road in front of me, and on the sides! As users have stated, the plug in LEDs get projected everywhere, instead of being focused like the stock bulb.
So my question(s)....
1. What Headlights are the best replacement with the least amount of work.
I'm torn between the HID and LED replacements from XenonDepot. The LED seem like really simple plug and play, but worried their brightness wouldn't be a vast improvement, and I don't know about the 6000K color...I want bright white, not blue, with the most lumens possible.
The HID replacements don't tell me how to install them. Do I need to connect wires to the battery? Do I need a CANBUS??
With the Fogs I want to be able to use the standard fog lights switch in the truck, so whats my best bet there? It seems like the Rigid D-Series lights would require me to totally rewire the connection into the truck.
Also, How do you adjust the aim of the standard fogs?
Thanks and Merry Christmas!
plus 1 on the kit from retrofit source. the difference is huge. i also got the projector style LED foglights that they have. they are really good at lighting up the ditch. The fog lights look way better when the truck is not on too as the housing is black. I recommend both. the install was super easy and the lighting is WAY better. plus the 5000k bulbs look way better in the truck.
I have XD led lamp and fog bulbs. The hlamps are a little better than stock. With hlamp and fogs on its much better than stock. It still could be better. Buts it's better than stock and much better color.
Really impressed with these. Much brighter, same as the Putco (Look to be identical) the light output is great, not just cosmetic. easy install. Seem to be brighter than my starnil 40/80W H11 LEDs. Also have $10 next day shipping (not amazon prime) I ordered on a saturday afternoon and got them on Sunday afternoon, blew me away -fastest shipping I've ever experienced. The price is right too.
http://www.amazon.com/Partsam-2500lm-2-cree-Driving-Headlight/dp/B00X5S13E6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1450929476&sr=1-1&keywords=partsam+H16+led+2500lm
I recommend the 35watt 5500k morimoto set from the retrofit source (they say those are about the same as many factory 4300k HID's), and if purchased together you get a little break on the XB foglights. The foglights actually work well in fog, and in really thick fog it's nice you can turn them on without the headlights. The HID's go in without a hitch, but the "sierra" set isn't really custom for the sierra, and they don't advise you were to mount stuff. I'd recommend extending the ground lead from the capacitor harness so you can connect both grounds at the battery. I've seen at least one video where they take half the truck apart to install these HID's and that's totally stupid. You don't need to take anything apart except the air intake. I got a stepped drill and opened up a hole in the dust caps to (don't remember exactly the fraction) - just shy of an inch for the rubber grommets.
The output is terrific, there are only just a few slightly dimmer spots in the beam pattern, (insert the bulbs very carefully in the right position and you'll have it right the first time) but the few slightly dim spots are not really near the area that needs lit up, and the XB foglights fill that area in really nicely. The XB foglights I got needed the wiring reversed. They recommend reversing the plug when you plug them it - but that was pretty cheesy. I clipped the wires and soldered them up backwards - in order to make them plug in and work properly. If you do that - be aware soldered joints can be brittle and prone to break, so protect that joint appropriately, and zip tie it up so it's not wiggling around.
The XB fogs are not the same as the Putco's by the way - not at all.
Somewhere on this site I saw a coupon....
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
